Como obtener el valor de un textInput en adobe Animate Canvas?
Feb 03, 2017 Feb 03, 2017
hola, estoy creando un pequeño proyecto, pero quiero saber como obtener el valor ingresado en un componente Input? este es mi código, pero no consigo como hacer que funcione.
this.stop();
this.textoEjemplo;
this.obtenerValor.on("click", function(){
  console.log($(root.texoEjemplo).value());
366
Community Expert , Feb 03, 2017 Feb 03, 2017
try:
this.obtenerValor.addEventListener('click', clickF);
function clickF(){
textoExjemploF(this);
function textoEjemploF(tl) {
if(tl.textoEjemplo.value == 10){
console.log(tl.textoEjemplo.value);
}else{
console.log("no es igual");
use:
this.stop ();
this.textoEjemplo;
this.obtenerValor.on ("click", function() {}
Console.log ($(#texoEjemplo) .val ());  // assuming texoExjemplo is in the current scope/context
Hi, your answer generate an error in the print  Console.log ($(#texoEjemplo) .val ());
that should be console.log
yes, but the problem is this simbol # in console.log ($(#texoEjemplo) .val ());
There the error is generated.
I have this code,
if(!this.textoEjemplo_change_cbk) {//(textoEjemplo_change_cbk), I don't know  what will be this
  function textoEjemplo_change(evt) {
  if(evt.target.value == 10){
  console.log(evt.target.value);
  }else{
  $("#dom_overlay_container").on("change", "#textoEjemplo", textoEjemplo_change.bind(this));
  this.textoEjemplo_change_cbk = true;
For get the value of Input, but I don't want use this code, I want implement in a button, for be executed when clicked and not enter.
let's try that again,
function ti_change(e) {
console.log(e.target.value);
$("#dom_overlay_container").on("change", "#texoEjemplo", ti_change.bind(this));
Ok friend, I'm sorry, I didn't understand me, I want implement this code in a button for be executed when I press the button. for this I have this code.
//Here I get this value of the input, but I want implement a button for executed this code doing click and not pressing enter key
  }else{
but doesn't run when clicked, only is executed when is pressed the enter key
this code only is executed when is pressed the enter key, I don't want that
try:
function clickF(){
}else{
Feb 08, 2017 Feb 08, 2017
thanks, kglad.com. you are genial
you're welcome.
