hola, estoy creando un pequeño proyecto, pero quiero saber como obtener el valor ingresado en un componente Input? este es mi código, pero no consigo como hacer que funcione.
this.stop();
this.textoEjemplo;
this.obtenerValor.on("click", function(){
console.log($(root.texoEjemplo).value());
try:
this.obtenerValor.addEventListener('click', clickF);
function clickF(){
textoExjemploF(this);
function textoEjemploF(tl) {
if(tl.textoEjemplo.value == 10){
console.log(tl.textoEjemplo.value);
}else{
console.log("no es igual");
use:
this.stop ();
this.textoEjemplo;
this.obtenerValor.on ("click", function() {}
Console.log ($(#texoEjemplo) .val ()); // assuming texoExjemplo is in the current scope/context
Hi, your answer generate an error in the print Console.log ($(#texoEjemplo) .val ());
that should be console.log
yes, but the problem is this simbol # in console.log ($(#texoEjemplo) .val ());
There the error is generated.
I have this code,
if(!this.textoEjemplo_change_cbk) {//(textoEjemplo_change_cbk), I don't know what will be this
function textoEjemplo_change(evt) {
if(evt.target.value == 10){
console.log(evt.target.value);
}else{
$("#dom_overlay_container").on("change", "#textoEjemplo", textoEjemplo_change.bind(this));
this.textoEjemplo_change_cbk = true;
For get the value of Input, but I don't want use this code, I want implement in a button, for be executed when clicked and not enter.
let's try that again,
function ti_change(e) {
console.log(e.target.value);
$("#dom_overlay_container").on("change", "#texoEjemplo", ti_change.bind(this));
Ok friend, I'm sorry, I didn't understand me, I want implement this code in a button for be executed when I press the button. for this I have this code.
//Here I get this value of the input, but I want implement a button for executed this code doing click and not pressing enter key
}else{
but doesn't run when clicked, only is executed when is pressed the enter key
this code only is executed when is pressed the enter key, I don't want that
try:
function clickF(){
}else{
thanks, kglad.com. you are genial
you're welcome.
