I am essentially PS illiterate but have been searching forums and tutorials trying to find a solution to my query which I would think is simple - either its not or Im just not seeing the solution I need-
I need to draw a series of cut of lines on well log cross sections, these will change and need to show various cut offs in the same spot to ideally this is done on a separate layer i can turn on or off - the problem im having is that I cant seem to copy the original line work to a new layer. Someone suggested I just trace it with the pen tool but that is extremely laborious and not a practical solution. The big issue here is that the original file is a crappy black and white grid with a even worse squiggly line which crosses back and forth (see below).
To reiterate - The black and white is the original, I need to draw the yellow vertical line and shade the portion to the left. Over time this line will move and is repeated on several neighboring logs so if i have to change one I would prefer not to redraw the entire thing.
Any thoughts for the FNG would be much appreciated as the example below was done in paint.
EDIT [moved to correct product forum – moderator]
[Here is a list of all Adobe Communities https://forums.adobe.com/welcome]
spencerp89265527 wrote:
Unfortunately no. Its all old paper logs from the 70's-80's which the government did a horrible job scanning and compiling a database of raster .tiff files.
In that case I think the best you are going to do is with the shape tool to paint a line and the paint bucket tool to fill each square (or part of square) you can do both of these on new layers. It does not take long. N.B: I have deliberately move the line one square to the right for this demo.
Dave
Just to make sure: Is the data present as vector data or numeric tables at any time?
Dave
Thanks Dave! Ill look into this shape file this weekend....Until now I didnt even know what tool to start researching so this is a big help.
No problem .
The shape tool just gave a line
After that I used the Paint bucket tool, clicking in each square in turn:
The paint bucket tool fills to the edge around which you click. If there is a gap - fill it with the brush tool before using paint
Dave
Hold on, Sorry I didnt realize what you had said before - Yes I can make a line and use the paint bucket, I had that figured out with the exception of the layers which is what prompted this discussion in the first place.
So knowing that, the problem I was having was after creating a new layer and drawing the line with shape, the paint bucket tool wouldnt recognize the squiggly line. I had assumed this was because the orig file with the squigle was "underneath" the layer I was drawing on.
Any thoughts why That might be happening?
Have you got All Layers checked?
Hi
Yes I filled onto a separate layer.
Select the layer you want to fill onto (create an empty layer above the image). As Trevor said - Check "All layers" in the options bar. That way it will see the lines on other layers as edges.
The other control to look at is the Tolerance value. If you find that the fill is leaving a gap or overshooting and filling outside the lines - adjust the value.
Dave
