Ive recently bought AE and i want to render in WMV format for my editin software but when i go to click on add to media encoder queue it says this:
https://gyazo.com/f3d60ba0543461f95a3a32e35589201d
And when i type in the link it says there is no download link for that plugin.
PLEASE CAN SOMEONE PROVIDE ME WITH A DOWNLOAD LINK OR HELP ME
Thanks Lewis
In my case, though the warning clearly stated that the plugin was not installed (and even gave a link to where to obtain it), the actual problem turned out to be a mismatch between the versions of After Effects and Premier that I was using. Updated the older one, and it works fine.
Hope that works for you.
You need to install and run AE with sufficient privileges and no external influences interfering. DynamicLink not working means that some other process on your system is messing around and blocking the required local ports/ sockets. You are completely misunderstanding teh warning.
Mylenium
"You are completely misunderstanding teh [sic] warning."
Really? The warning says simply that the plugin is not installed, and advises to download and install. I don't doubt that conflicts caused by permissions may be the reason it did not install properly (or is not working), but where in the warning does it say that?
You know as well as EVERYONE on your team that this crap breaks ALL THE FREAKING TIME after even a minor update. I am absolutely sick of Adobe laying their failures at the feet of their customers who are paying to be beta testers. My AEDynamicLink just went down AGAIN. AGAIN. AND AGAIN. OVER AND FREAKING OVER. FIX YOUR MISTAKES, ADOBE.
Concordo plenamente, por isso fiz o cancelamento da assinatura, pois pagar por algo que funciona quando quer, e ainda quando funciona, funciona travando, os programas frees da internet rodam redondo e sem travas, por exemplo, o Premier fica travando o tempo todo no preview, ai penso que o problema são os arquivos gravados, quando rodo esses mesmo arquivos no capcut ele roda sem nenhum problema. Desisti da Adobe, pra mim acabou.
Estou com o mesmo problema, diz que o dynamic não está na maquina, pede pra fazer o donwload, mas não tem link nenhum para tal, isso é apenas bug da porcaria dos programas da Adobe.
What a meta answer. It would help to be precise, as it seems to be a serious issue and pepz need to work and deliver with these products and for that they need to be function perfectly!
It would be awesome if adobe stimultansously come up with "AE ME PR program package updates" instead of freaking hour consuming one-by-one puzzling with the right versions via the CC UI....
Cheers, your welcome.
P.S: once again now landed in 2022! Wow
Hi Lewis,
Did you follow Mylenium's advice and did it assist you? Please let us know if you solved your issue or not, and if you still need help.
Kevin
I need help for this issue.....
Hey Adobe
Shame on you, is this error informative enought for users who pay you so much?
I am paying this product to work not to solve your sh**s
Thanks to users you are alive, so don't mess wit us...
Still need help for this Issue..
Thank you
this is absolut nonsens that you have to solve this isue by your self.
It hepled me
