After Effects Launches but No Windows Open - El Capitan
Feb 04, 2017 Feb 04, 2017
What I thought was happening was the After Effects windows were located off screen, as I'm running a separate external monitor.  However, I've tried numerous things and can't get any windows to show up. All of my other creative cloud apps open and run fine, and I've had AE running fine on this machine before.
After Effects launches, no splash page comes up on screen like the other creative cloud apps showing the program launching. The file, edit, etc, menu bar comes up in the upper left hand corner. Initially I'm unable to select any options in the dropdown menus, however, if I hit enter I'm able to select options like open new project, etc.  Nothing happens when I select any of those or any of the window layout options as well.
So far I've tried reseting the app preference by deleting the pref file manually, as well as launching the program with command + option + shift held down.
I've tried changing both of my screens resolutions to see if the windows are located off screen, which didn't work
I've uninstalled, restarted and reinstalled a few different versions of AE: Versions 14.0.1, 14.0.0, 13.8.0 I get the same thing with all of them.
Tried doing first aid in the disk utility on my main HD.
Here's my specs:
Macbook Pro Mid 2009
OS X El Capitan
2.8 GHz Intel Core 2 Duo
8GB RAM
Nvidia Geforce 9600 GT 512MB
Thanks for any help!
364
What version of AE? Did it ever work? Did you try resetting your external monitor to Mirror? Do you see the AE program icon bouncing in the dock when you try and open AE? Can you see the AE icon when you use Ctrl/Cmnd + tab to switch between programs.
The only time I had this happen with my MacBook pro I was editing with a 4K monitor connected and I'd moved AE completely to the 4K monitor, then I forgot to move it back when I shut down and went back to my studio. I set the display preferences to maximum resolution and then reset them and nuked my AE preferences on launch and it showed back up. I'm on Sierra now and have not had the same problem again.
Hi Rick,
I tried the 3 latest versions 14.0.1,14.0.0,13.8.0
Also tried mirroring the monitors, still nothing.
I can see the AE icon bouncing when it opens and I can cmd+tab to switch to the application, but none of the windows show up at all. It's very strange.
Can you right click on the icon in the dock and select display in another desktop or All desktops or this desktop? It's an idea...
I guess you figured out I'm working in Lightroom right now..
I don't think El Capitan has that assign to function, it doesn't show up for me.
Adobe Employee ,
Mar 03, 2017 Mar 03, 2017
Hi JaradT,
Apologies for this frustration. Are you still experiencing this UI weirdness? I suggest you work with our agents on this issue. Please let us know the solution if you found one.
Kevin
