please can someone help me?
hello, i made banners for adwords, but the ain't clickable to our website...
i have used adwords banners with animate before, but after the 2017 upgrade, i didn't used it.
i have changed the template for the 2017 version, and the banners running, only no click??? ;-(
i've reed somewhere that the banners don't use a click tag anymore...is that true?
in adwords i can put the url link to the banner
( i make my banners together with greensock in code)
under here, the template: (is there anything i must change)
<!DOCTYPE html>
NOTES:
1. All tokens are represented by '$' sign in the template.
2. You can write your code only wherever mentioned.
3. All occurrences of existing tokens will be replaced by their appropriate values.
4. Blank lines will be removed automatically.
5. Remove unnecessary comments before creating your template.
<html>
<head>
<meta charset="UTF-8">
<meta name="authoring-tool" content="$VERSION">
<title>$TITLE</title>
<!-- write your code here -->
<meta name="ad.size" content="width=$WT,height=$HT">
<script src="https://s0.2mdn.net/ads/studio/cached_libs/createjs_2015.11.26_54e1c3722102182bb133912ad4442e19_min...."></script>
<script src="https://s0.2mdn.net/ads/studio/cached_libs/tweenmax_1.18.0_499ba64a23378545748ff12d372e59e9_min.js"></script>
<script src="https://tpc.googlesyndication.com/pagead/gadgets/html5/api/exitapi.js"></script>
$ANIMATE_CC_SCRIPTS
$SCRIPT_START
var canvas, stage, exportRoot, anim_container, dom_overlay_container, fnStartAnimation;
function init() {
canvas = document.getElementById("$CANVAS_ID");
anim_container = document.getElementById("$ANIM_CONTAINER_ID");
dom_overlay_container = document.getElementById("dom_overlay_container");
$CREATE_LOADER
$LOAD_MANIFEST
$PRELOAD_ASSETS
$HANDLE_FILE_LOAD_START
$HANDLE_FILE_LOAD_BODY
$HANDLE_FILE_LOAD_END
$HANDLE_COMPLETE_START
//This function is always called, irrespective of the content. You can use the variable "stage" after it is created in token create_stage.
$CREATE_STAGE
//Registers the "tick" event listener.
$START_ANIMATION
//Code to support hidpi screens and responsive scaling.
$RESP_HIDPI
$HANDLE_COMPLETE_END
$PLAYSOUND
$SCRIPT_END
</head>
<body onload="init();" style="margin:0px;">
<div id="$ANIM_CONTAINER_ID" style="background-color:$BG; width:$WTpx; height:$HTpx">
<canvas id="$CANVAS_ID" width="$WT" height="$HT" style="position: absolute; display: $CANVAS_DISP; background-color:$BG;"></canvas>
<div id="dom_overlay_container" style="pointer-events:none; overflow:hidden; width:$WTpx; height:$HTpx; position: absolute; left: 0px; top: 0px; display: $CANVAS_DISP;">
</div>
</div>
$PRELOADER_DIV
</body>
</html>
Have something to add?
