Lightroom CC 2015.8 freezes when coping settings. At least 4-5 times per hour. (almost every 3rd time)
Problem started right after the update.
Is there a fix coming soon or is it possible to roll back the LR to the previous version?
not possible to work this way....
Moving to Photoshop Lightroom​
Hi tambetk,
Please turn off the Graphics processor from the Lightroom preferences and check if that helps.
Open Lightroom > Edit menu > Preferences > Performance tab > Uncheck the Graphics processor > Restart
Mohit
never used gaphics processor for performance.
This is the feature added in Lightroom for improving the performance, but you should have eligible graphics cards installed in your machine. If you don't have one installed, then you can turn off the feature from the Performance tab in Lightroom.
Mohit
thank you for the explanation, I am fully aware what it is but I am not using it.
I dont have good enough graphic card on my macbook pro so using this feature slows down the Lightroom.
and also no - this does not help. tried it.
If you need to roll back to an earlier version, here's how:
http://www.lightroomqueen.com/how-do-i-roll-back-to-lightroom-2015-1-1-or-lightroom-6-1-1/
Simply replace 6.1.1 with 6.7 in the guide.
