Ummmm! OK I think we need to take a step back here. Firtly
can you confirm whether you are producing WebHelp here. Your
mention of CHM file has confused me a bit. Secondly, where is the
D: drive you mention? Is this accessible from where your webhelp
output (if that is what it is) is situated? As a word of advice, it
is much better to use relative rather than absolute links to
prevent this type of problem.
Finally is the D drive a network drive? If so, that's more
than likely your problem. Never, never,
never run your RH projects from a network drive. Also it is
advisible not to generate your output inside the !SSL! folder.
Create a folder off your C: drive and store all your source files
there. As far as your project name is concerned, do not use special
characters. Oh and the link you gave me is very long. If you adopt
the suggestion of having your project off your C: drive this would
cut down the path considerably.
