Hi!
I am trying to use the publish online feature of in design but it keeps coming out blurry!
I have changed the resolution to be the highest output and it certainly helped but it is still not the highest quality
my images are coming from photoshop, are 350 dpi and when i export as pdf on my computer it is crystal clear and can be zoomed in without loss of detail.
Help!
See if this recent posting on InDesignSecrets.com helps:
http://indesignsecrets.com/controlling-publish-online-image-resolution.php
Thank you! This fixed the issue
In case anyone is wondering, the indesign secrets link is to an article by Keith Gilbert that shows that using the Object > Object Export Options dialog box the EPUB and HTML tab allows you to set the specific controls for export to ePub which also controls much of the settings for Publish Online.
In addition, the article doesn't mention it, but you can also make an object style with these settings so it's easy to set the controls for many objects.
