How can I rotate all the text layers in a PSD document by Java Script
Guest
Feb 05, 2017 Feb 05, 2017
How can I rotate all the text layers in a PSD document by Java Script, Instead of, rotate the text layers one by one.
This is a pressing problem in the Engineering plan drawing. Thanks anyway!
                                                           by a Green hand
Actions and scripting
1.5K
Advocate , Feb 06, 2017 Feb 06, 2017
Hi buddy.
Try this script. Define the angle you want to rate and you should be good.
// Rotate all text layer by a given angle.
// Script by Tomas Sinkunas www.rendertom.com
(function(){
    #target photoshop
    // Define the angle.
    var angle = 180;
    // Collect all text layers in the document
    var textLayers = getTextLayers(app.activeDocument);
    // Loop through all text layers in the document
    for (var t = 0, tl = textLayers.length; t < tl ; t ++) {
        // Rotate the layer
        tex
Adobe
I've moved this from Photoshop General Discussion​ to Photoshop Scripting
It relatively easy to process all text layers in a document with a script.  However, rotating text layers well may be hard. Text can be a line or paragraph rotation can be done from any rotation point and can rotate text off canvas.  Text can be very complex to deal with.
JJMack
Guest
In the same way, rotate all the text layers whithin one document will be easy in AutoCAD software. But Adobe Photoshop Is another case. Maybe, Adobe Corp should deliberate what to do tomorrow.......
Advocate ,
Hi buddy.
(function(){
    #target photoshop
    var angle = 180;
        // Rotate the layer
        textLayers.rotate (angle, AnchorPosition.MIDDLECENTER);
    function getTextLayers (doc, layers) {
        layers = layers || [];
        for (var i = 0, il = doc.layers.length; i < il; i ++) {
            if (doc.layers.typename == "LayerSet") {
                getTextLayers(doc.layers, layers)
            } else {
                if (doc.layers.kind == "LayerKind.TEXT") {
                    layers.push(doc.layers)
        return layers
Guest
Tanks anyway!  I will have a tray. in addition,  I learn JS just a short time, So, I must Try and Try ...
