When working with multiple comps, After Effects remembers the zoom and the offset of the composition view for each comp.
I would like to know if its possible to disable this, or at least if there is a way to center/reset the composition view to a default position and scale.
I know there is the snapshot button, to compare between comps, but I find it too slow, and inconvenient when comparing more than 2 different compositions.
If you are not sure what I mean, here is an example of the composition view remembering the offset:
these shortcuts are all you got:
they will all center your composition view, but won't keep the magnification ratio. if you think there should be more options for this, you can ask for it here: After Effects keyboard shortcuts reference
Hi Roei,
I didn't know about the / hotkey, using alt+/ aligned all the views perfectly!
Thanks a lot!
yes, I use it all the time thanks for the feedback
