Can't open Premier. Hangs during splash screen.
Windows 7, SP1 - 64 bit
AMD II X4 630 2.80 GHz
6.0 GB RAM
Error log:
Log Name: Application
Source: Application Error
Date: 2/6/2017 11:40:03 AM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: jane-HP
Description:
Faulting application name: PhotoshopElementsOrganizer.exe, version: 15.0.0.0, time stamp: 0x57cd427e
Faulting module name: dvamarshal.dll, version: 8.0.0.0, time stamp: 0x535f7c68
Exception code: 0xc0000005
Fault offset: 0x000000000000ab79
Faulting process id: 0x994
Faulting application start time: 0x01d280978a64e212
Faulting application path: C:\Program Files\Adobe\Elements 15 Organizer\PhotoshopElementsOrganizer.exe
Faulting module path: C:\Program Files\Adobe\Elements 15 Organizer\dvamarshal.dll
Report Id: e7fe41a6-ec8a-11e6-8f1b-78e7d1c8cfdb
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2017-02-06T16:40:03.000000000Z" />
<EventRecordID>151726</EventRecordID>
<Channel>Application</Channel>
<Computer>jane-HP</Computer>
<Security />
</System>
<EventData>
<Data>PhotoshopElementsOrganizer.exe</Data>
<Data>15.0.0.0</Data>
<Data>57cd427e</Data>
<Data>dvamarshal.dll</Data>
<Data>8.0.0.0</Data>
<Data>535f7c68</Data>
<Data>c0000005</Data>
<Data>000000000000ab79</Data>
<Data>994</Data>
<Data>01d280978a64e212</Data>
<Data>C:\Program Files\Adobe\Elements 15 Organizer\PhotoshopElementsOrganizer.exe</Data>
<Data>C:\Program Files\Adobe\Elements 15 Organizer\dvamarshal.dll</Data>
<Data>e7fe41a6-ec8a-11e6-8f1b-78e7d1c8cfdb</Data>
</EventData>
</Event>
Rather than opening Premier Elements from the Organizer, can you find and open the "PremiereElementsEditor.exe" file?
Bill
We tried opening the Organizer and the main screen appears, but then hangs with the "This program has stopped working" message.
I'm not currently at the PC having the reported problem. Will not be back there until next week. Will check in with you then.
There are options built in so that you can completely ignore Organizer. Since I prefer Lightroom for organizing, I have my system set up to open Premier Elements directly and never see the Elements Organizer.
Thanks, but even if we don't attempt to open the organizer, we can't open Premiere directly. It hangs at the splash screen.
That get harder and is above my pay grade! The usual series is to examine available memory space, HDD space, uninstalling and reinstalling.
This is a user forum on space provided by Adobe. Adobe themselves has a "chat" support system where they can go as far as running your computer for you to find what is wrong with the installation. Reports are that they are good at fixing it.
Try starting here: https://helpx.adobe.com/contact.html?step=PRE
Good luck!
Bill
Thanks Bill. Will contact them when I'm back at the PC in question.
