I can draw, but I can't actually see my artwork. I know drawing is working, because I can see it in the navigator. When I turn the option to Use Graphic processor, I can see the canvas just fine. Has anyone else run into this issue?
Which model use Photoshop menu Help>system info copy an paste info here
Adobe Photoshop Version: 2017.0.1 20161130.r.29 2016/11/30:23:00:00 CL 1099099 x64
Number of Launches: 25
Version: 10 or greater
System architecture: Intel CPU Family:6, Model:14, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
Physical processor count: 2
Logical processor count: 4
Processor speed: 2496 MHz
Built-in memory: 8118 MB
Free memory: 2 MB
Memory available to Photoshop: 6918 MB
Memory used by Photoshop: 70 %
History Thumbnails: Enabled.
Touch Bar: Enabled.
Alias Layers: Disabled.
Modifier Palette: Enabled.
3D Multitone Printing: Disabled.
Highbeam: Enabled.
Image tile size: 128K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=1000, right=1500
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=2
NumNativeGPUs=0
glgpu[0].GLVersion="4.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=1024
glgpu[0].GLName="Intel(R) HD Graphics 520"
glgpu[0].GLVendor="Intel"
glgpu[0].GLVendorID=32902
glgpu[0].GLDriverVersion="20.19.15.4463"
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="Intel(R) HD Graphics 520"
glgpu[0].GLRendererID=6422
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igd12umd64.dll,igdumdim32,igd10iumd32,igd10iumd32,igd12umd32"
glgpu[0].GLDriverDate="20160706000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.30 - Build 20.19.15.4463"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1447]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[64]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=0
clgpu[0].CLPlatformVersion="2.0 "
clgpu[0].CLDeviceVersion="2.0 "
clgpu[0].IsIntegratedCLGPU=1
clgpu[0].CLMemoryMB=3239
clgpu[0].CLName="Intel(R) HD Graphics 520"
clgpu[0].CLVendor="Intel(R) Corporation"
clgpu[0].CLVendorID=32902
clgpu[0].CLDriverVersion="20.19.15.4463"
clgpu[0].CLBandwidth=1.68511e+10
clgpu[0].CLCompute=167.397
clgpu[1].CLPlatformVersion="1.2"
clgpu[1].CLDeviceVersion="1.2 CUDA"
clgpu[1].IsIntegratedCLGPU=0
clgpu[1].CLMemoryMB=1024
clgpu[1].CLName="GeForce GPU"
clgpu[1].CLVendor="NVIDIA Corporation"
clgpu[1].CLVendorID=4318
clgpu[1].CLDriverVersion="378.49"
clgpu[1].CLBandwidth=3.44544e+10
clgpu[1].CLCompute=233.417
License Type: Subscription
Serial number: [Serial number removed by moderator]
GUIDBucket:
bucket: 13
test: control
Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
Temporary file path: C:\Users\kmurp\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 235.5G, 143.3G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-Ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\
Installed components:
A3DLIBS.dll A3DLIB Dynamic Link Library 9.2.0.112
ACE.dll ACE 2016/11/04-01:10:53 79.578171 79.578171
AdbePM.dll PatchMatch 2016/11/03:19:48:57 1.578146 1.578146
AdobeLinguistic.dll Adobe Linguisitc Library 10.0.0
AdobeOwl.dll Adobe Owl 5.2.11
AdobePDFL.dll PDFL 2016/08/10-16:53:20 79.195992 79.195992
AdobePIP.dll Adobe Product Improvement Program 7.4.1.60.45263
AdobeSVGAGM.dll AdobeSVGAGM 79.578171 79.578171
AdobeXMP.dll Adobe XMP Core 2016/09/14-01:09:01 79.159824 79.159824
AdobeXMPFiles.dll Adobe XMP Files 2016/09/14-01:09:01 79.159824 79.159824
AdobeXMPScript.dll Adobe XMP Script 2016/09/14-01:09:01 79.159824 79.159824
adobe_caps.dll Adobe CAPS 10,0,0,6
AGM.dll AGM 2016/11/04-01:10:53 79.578171 79.578171
ahclient.dll AdobeHelp Dynamic Link Library 2.0.0.2
AIDE.dll AIDE 2016/05/27-01:08:49 79.574279 79.574279
amtlib.dll AMTLib (64 Bit) 10.0.0.47 BuildVersion: 10.0; BuildDate: Thu Sep 1 2016 5:16:17) 1.000000
ARE.dll ARE 2016/11/04-01:10:53 79.578171 79.578171
AXE8SharedExpat.dll AXE8SharedExpat 2015/03/13-23:40:54 79.562390 79.562390
AXEDOMCore.dll AXEDOMCore 2015/03/13-23:40:54 79.562390 79.562390
Bib.dll BIB 2016/11/04-01:10:53 79.578171 79.578171
BIBUtils.dll BIBUtils 2016/11/04-01:10:53 79.578171 79.578171
boost_date_time.dll photoshopdva 10.0.0
boost_signals.dll photoshopdva 10.0.0
boost_system.dll photoshopdva 10.0.0
boost_threads.dll photoshopdva 10.0.0
cg.dll NVIDIA Cg Runtime 3.0.00007
cgGL.dll NVIDIA Cg Runtime 3.0.00007
CIT.dll Adobe CIT 2.1.0.1 2.1.0.1
CITThreading.dll Adobe CITThreading 2.1.0.1 2.1.0.1
CoolType.dll CoolType 2016/11/04-01:10:53 79.578171 79.578171
dnssd.dll Bonjour 3,0,0,2
dvaaudiodevice.dll photoshopdva 10.0.0
dvacore.dll photoshopdva 10.0.0
dvamarshal.dll photoshopdva 10.0.0
dvamediatypes.dll photoshopdva 10.0.0
dvametadata.dll photoshopdva 10.0.0
dvametadataapi.dll photoshopdva 10.0.0
dvametadataui.dll photoshopdva 10.0.0
dvaplayer.dll photoshopdva 10.0.0
dvatransport.dll photoshopdva 10.0.0
dvaui.dll photoshopdva 10.0.0
dvaunittesting.dll photoshopdva 10.0.0
dynamiclink.dll photoshopdva 10.0.0
ExtendScript.dll ExtendScript 2016/01/26-16:09:33 80.1060872 80.1060872
icucnv40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icudt40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icuuc40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
igestep30.dll IGES Reader 9.3.0.113
imslib.dll IMSLib DLL 10.0.0.1
JP2KLib.dll JP2KLib 2016/05/26-01:08:58 79.262945 79.262945
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libiomp5md.dll Intel(R) OpenMP* Runtime Library 5.0
libmmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
LogSession.dll LogSession 7.4.1.60.45263
mediacoreif.dll photoshopdva 10.0.0
MPS.dll MPS 2016/09/14-15:20:26 79.577269 79.577269
pdfsettings.dll Adobe PDFSettings 1.04
Photoshop.dll Adobe Photoshop CC 2017 18.0.1
Plugin.dll Adobe Photoshop CC 2017 18.0.1
PlugPlugExternalObject.dll Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit) 7.0.0
PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit) 7.0.0.67
PSArt.dll Adobe Photoshop CC 2017 18.0.1
PSViews.dll Adobe Photoshop CC 2017 18.0.1
SCCore.dll ScCore 2016/01/26-16:09:33 80.1060872 80.1060872
SVGRE.dll SVGRE 79.578171 79.578171
svml_dispmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
tbb.dll Intel(R) Threading Building Blocks for Windows 4, 4, 2016, 0412
tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 4, 4, 2016, 0412
TfFontMgr.dll FontMgr 9.3.0.113
TfKernel.dll Kernel 9.3.0.113
TFKGEOM.dll Kernel Geom 9.3.0.113
TFUGEOM.dll Adobe, UGeom© 9.3.0.113
updaternotifications.dll Adobe Updater Notifications Library 10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 10.0.0.1
VulcanControl.dll Vulcan Application Control Library 5.3.0.16
VulcanMessage5.dll Vulcan Message Library 5.3.0.16
WRServices.dll WRServices Thu Jan 07 2016 04:50:10 Build 0.21960 0.21960
wu3d.dll U3D Writer 9.3.0.113
Required plug-ins:
3D Studio 18.0.1 (2017.0.1 x001 x003) - from the file “U3D”
Accented Edges 18.0.1 - from the file “Filter Gallery”
Adaptive Wide Angle 18.0.1 - from the file “Adaptive Wide Angle”
Angled Strokes 18.0.1 - from the file “Filter Gallery”
Average 18.0.1 (2017.0.1 x001 x003) - from the file “Average”
Bas Relief 18.0.1 - from the file “Filter Gallery”
BMP 18.0.1 - from the file “Standard MultiPlugin”
Camera Raw 9.8 - from the file “Camera Raw”
Camera Raw Filter 9.8 - from the file “Camera Raw”
Chalk && Charcoal 18.0.1 - from the file “Filter Gallery”
Chrome 18.0.1 - from the file “Filter Gallery”
Cineon 18.0.1 (2017.0.1 x001 x003) - from the file “Cineon”
Clouds 18.0.1 (2017.0.1 x001 x003) - from the file “Clouds”
Collada 18.0.1 (2017.0.1 x001 x003) - from the file “U3D”
Color Halftone 18.0.1 - from the file “Standard MultiPlugin”
Colored Pencil 18.0.1 - from the file “Filter Gallery”
CompuServe GIF 18.0.1 - from the file “Standard MultiPlugin”
Conté Crayon 18.0.1 - from the file “Filter Gallery”
Craquelure 18.0.1 - from the file “Filter Gallery”
Crop and Straighten Photos 18.0.1 (2017.0.1 x001 x003) - from the file “CropPhotosAuto”
Crop and Straighten Photos Filter 18.0.1 - from the file “Standard MultiPlugin”
Crosshatch 18.0.1 - from the file “Filter Gallery”
Crystallize 18.0.1 - from the file “Standard MultiPlugin”
Cutout 18.0.1 - from the file “Filter Gallery”
Dark Strokes 18.0.1 - from the file “Filter Gallery”
De-Interlace 18.0.1 - from the file “Standard MultiPlugin”
Dicom 18.0.1 - from the file “Dicom”
Difference Clouds 18.0.1 (2017.0.1 x001 x003) - from the file “Clouds”
Diffuse Glow 18.0.1 - from the file “Filter Gallery”
Displace 18.0.1 - from the file “Standard MultiPlugin”
Dry Brush 18.0.1 - from the file “Filter Gallery”
Eazel Acquire 18.0.1 (2017.0.1 x001 x003) - from the file “EazelAcquire”
Entropy 18.0.1 (2017.0.1 x001 x003) - from the file “statistics”
Export Color Lookup Tables NO VERSION - from the file “Export3DLUT”
Extrude 18.0.1 - from the file “Standard MultiPlugin”
FastCore Routines 18.0.1 (2017.0.1 x001 x003) - from the file “FastCore”
Fibers 18.0.1 - from the file “Standard MultiPlugin”
Film Grain 18.0.1 - from the file “Filter Gallery”
Filter Gallery 18.0.1 - from the file “Filter Gallery”
Flash 3D 18.0.1 (2017.0.1 x001 x003) - from the file “U3D”
Fresco 18.0.1 - from the file “Filter Gallery”
Glass 18.0.1 - from the file “Filter Gallery”
Glowing Edges 18.0.1 - from the file “Filter Gallery”
Google Earth 4 18.0.1 (2017.0.1 x001 x003) - from the file “U3D”
Graphic Pen 18.0.1 - from the file “Filter Gallery”
Halftone Pattern 18.0.1 - from the file “Filter Gallery”
HDRMergeUI 18.0.1 - from the file “HDRMergeUI”
HSB/HSL 18.0.1 - from the file “Standard MultiPlugin”
IFF Format 18.0.1 - from the file “Standard MultiPlugin”
IGES 18.0.1 (2017.0.1 x001 x003) - from the file “U3D”
Ink Outlines 18.0.1 - from the file “Filter Gallery”
JPEG 2000 18.0.1 - from the file “JPEG2000”
Kurtosis 18.0.1 (2017.0.1 x001 x003) - from the file “statistics”
Lens Blur 18.0.1 - from the file “Lens Blur”
Lens Correction 18.0.1 - from the file “Lens Correction”
Lens Flare 18.0.1 - from the file “Standard MultiPlugin”
Liquify 18.0.1 - from the file “Liquify”
Matlab Operation 18.0.1 (2017.0.1 x001 x003) - from the file “ChannelPort”
Maximum 18.0.1 (2017.0.1 x001 x003) - from the file “statistics”
Mean 18.0.1 (2017.0.1 x001 x003) - from the file “statistics”
Measurement Core 18.0.1 (2017.0.1 x001 x003) - from the file “MeasurementCore.8me”
Median 18.0.1 (2017.0.1 x001 x003) - from the file “statistics”
Mezzotint 18.0.1 - from the file “Standard MultiPlugin”
Minimum 18.0.1 (2017.0.1 x001 x003) - from the file “statistics”
MMXCore Routines 18.0.1 (2017.0.1 x001 x003) - from the file “MMXCore”
Mosaic Tiles 18.0.1 - from the file “Filter Gallery”
Multiprocessor Support 18.0.1 (2017.0.1 x001 x003) - from the file “MultiProcessor Support”
Neon Glow 18.0.1 - from the file “Filter Gallery”
Note Paper 18.0.1 - from the file “Filter Gallery”
NTSC Colors 18.0.1 (2017.0.1 x001 x003) - from the file “NTSC Colors”
Ocean Ripple 18.0.1 - from the file “Filter Gallery”
OpenEXR 18.0.1 - from the file “Standard MultiPlugin”
Paint Daubs 18.0.1 - from the file “Filter Gallery”
Palette Knife 18.0.1 - from the file “Filter Gallery”
Patchwork 18.0.1 - from the file “Filter Gallery”
Paths to Illustrator 18.0.1 - from the file “Standard MultiPlugin”
PCX 18.0.1 (2017.0.1 x001 x003) - from the file “PCX”
Photocopy 18.0.1 - from the file “Filter Gallery”
Photoshop 3D Engine 18.0.1 (2017.0.1 x001 x003) - from the file “Photoshop3DEngine”
Photoshop Touch 14.0 - from the file “PSDX”
Picture Package Filter 18.0.1 (2017.0.1 x001 x003) - from the file “ChannelPort”
Pinch 18.0.1 - from the file “Standard MultiPlugin”
Pixar 18.0.1 (2017.0.1 x001 x003) - from the file “Pixar”
Plaster 18.0.1 - from the file “Filter Gallery”
Plastic Wrap 18.0.1 - from the file “Filter Gallery”
PLY 18.0.1 (2017.0.1 x001 x003) - from the file “U3D”
PNG 18.0.1 - from the file “Standard MultiPlugin”
Pointillize 18.0.1 - from the file “Standard MultiPlugin”
Polar Coordinates 18.0.1 - from the file “Standard MultiPlugin”
Portable Bit Map 18.0.1 (2017.0.1 x001 x003) - from the file “PBM”
Poster Edges 18.0.1 - from the file “Filter Gallery”
PRC 18.0.1 (2017.0.1 x001 x003) - from the file “U3D”
Radial Blur 18.0.1 - from the file “Standard MultiPlugin”
Radiance 18.0.1 (2017.0.1 x001 x003) - from the file “Radiance”
Range 18.0.1 (2017.0.1 x001 x003) - from the file “statistics”
Render Color Lookup Grid NO VERSION - from the file “Export3DLUT”
Reticulation 18.0.1 - from the file “Filter Gallery”
Ripple 18.0.1 - from the file “Standard MultiPlugin”
Rough Pastels 18.0.1 - from the file “Filter Gallery”
Save for Web 18.0.1 - from the file “Save for Web”
ScriptingSupport 18.0.1 - from the file “ScriptingSupport”
Shake Reduction 18.0.1 - from the file “Shake Reduction”
Shear 18.0.1 - from the file “Standard MultiPlugin”
Skewness 18.0.1 (2017.0.1 x001 x003) - from the file “statistics”
Smart Blur 18.0.1 - from the file “Standard MultiPlugin”
Smudge Stick 18.0.1 - from the file “Filter Gallery”
Solarize 18.0.1 (2017.0.1 x001 x003) - from the file “Solarize”
Spaces 18.0.1 - from the file “Spaces”
Spatter 18.0.1 - from the file “Filter Gallery”
Spherize 18.0.1 - from the file “Standard MultiPlugin”
Sponge 18.0.1 - from the file “Filter Gallery”
Sprayed Strokes 18.0.1 - from the file “Filter Gallery”
Stained Glass 18.0.1 - from the file “Filter Gallery”
Stamp 18.0.1 - from the file “Filter Gallery”
Standard Deviation 18.0.1 (2017.0.1 x001 x003) - from the file “statistics”
STL 18.0.1 (2017.0.1 x001 x003) - from the file “U3D”
Sumi-e 18.0.1 - from the file “Filter Gallery”
Summation 18.0.1 (2017.0.1 x001 x003) - from the file “statistics”
Targa 18.0.1 - from the file “Standard MultiPlugin”
Texturizer 18.0.1 - from the file “Filter Gallery”
Tiles 18.0.1 - from the file “Standard MultiPlugin”
Torn Edges 18.0.1 - from the file “Filter Gallery”
Twirl 18.0.1 - from the file “Standard MultiPlugin”
U3D 18.0.1 (2017.0.1 x001 x003) - from the file “U3D”
Underpainting 18.0.1 - from the file “Filter Gallery”
Vanishing Point 18.0.1 - from the file “VanishingPoint”
Variance 18.0.1 (2017.0.1 x001 x003) - from the file “statistics”
Virtual Reality Modeling Language | VRML 18.0.1 (2017.0.1 x001 x003) - from the file “U3D”
Water Paper 18.0.1 - from the file “Filter Gallery”
Watercolor 18.0.1 - from the file “Filter Gallery”
Wave 18.0.1 - from the file “Standard MultiPlugin”
Wavefront|OBJ 18.0.1 (2017.0.1 x001 x003) - from the file “U3D”
WIA Support 18.0.1 (2017.0.1 x001 x003) - from the file “WIASupport”
Wind 18.0.1 - from the file “Standard MultiPlugin”
Wireless Bitmap 18.0.1 (2017.0.1 x001 x003) - from the file “WBMP”
ZigZag 18.0.1 - from the file “Standard MultiPlugin”
Optional and third party plug-ins: NONE
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
com.adobe.inapp.purchase 2.7.122 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\purchase.html”
Recent Files 1.4.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.ccx.start\index.html”
Libraries 2.7.122 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\index.html”
New Document 1.4.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.ccx.start\fnft.html”
Start 1.4.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.ccx.start\index.html”
com.adobe.experimentation.extension 2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.experimentation.extension\index.html”
Adobe Color Themes 6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
Export As 3.0.8 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
Device Preview 1.3.1 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSPanel\panel.html”
com.adobe.preview.loader 1.3.1 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSLoader\loader.html”
Installed TWAIN devices: NONE
Does it fail when the keyboard is not connected? I often wondered about the surface Book wit two different GPU in it when the keyboard is attached. Photoshop is known to have problems on some machines when there are two different GPU installed and configured.
just reset my surfacebook yesterday and I'm having the same issue. when its not connected to the keyboard, it defaults to the intel gpu and everything display normally.
Dock the keyboard See if there is a setting in the Nvidia control panel that let you set the Nvidia as the GPU for Photoshop so both will not be use for Photoshop when docked.
that's the issue, when you have the NVidia selected it does not work. you have to uncheck use graphic processor if you want your images to show
