Trying for ages to create the prov file for Premiere Elements 12, keep getting error code 14, tried at work, at home of different computers same issue.
Command:
C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\Enterprise\utilities\APTEE\CS6\adobe_prtk.exe --tool=VolumeSerialize --generate --serial=(myserial) --leid=V7{}PremiereElements-EMT[12]-Win-GM --regsuppress=ss --EulaSuppress
Here is the log file. what am i doing wrong?
2017-02-07 21:18:22 [3340] Adobe PRTK: *** Adobe PRTK tool START ***
2017-02-07 21:18:22 [3340] Adobe PRTK: Adobe PRTK tool VolumeSerialize invoked
2017-02-07 21:18:22 [3340] Adobe PRTK: .
2017-02-07 21:18:22 [3340] Adobe PRTK: creating .\prov.xml
2017-02-07 21:18:22 [3340] OOBELib: __OOBELIB_LOG_FILE__
2017-02-07 21:18:22 [3340] OOBELib: *************OOBELib Session Starts*************
2017-02-07 21:18:22 [3340] OOBELib: Version 6.2.0.43,6.2
2017-02-07 21:18:22 [3340] PCDService: PCD Service in non-threaded mode
2017-02-07 21:18:22 [3340] OPMWrapper: Failed in getting value for key in OPMGetValueForKey
2017-02-07 21:18:22 [3340] OOBELib: Failed to get Proxy username in OPM DB
2017-02-07 21:18:22 [3340] AXFBLicensing: Failed to load axlib.dll, trying again
2017-02-07 21:18:22 [3340] AXFBLicensing: Failed to load axlib.dll, trying again with axlib in ACF
2017-02-07 21:18:22 [3340] AXFBLicensing: All function pointers successfully retrieved
2017-02-07 21:18:22 [3340] OOBELib: Received Params for Online Validation : Driver : V7{}PremiereElements-EMT[12]-Win-GM, Caller : 3
2017-02-07 21:18:22 [3340] OOBELib: received LEID : V7{}PremiereElements-EMT[12]-Win-GM
2017-02-07 21:18:22 [3340] OOBELib: Supported Locales : ALL
2017-02-07 21:18:22 [3340] OOBELib: OOBELib ValidateSerialOnline
2017-02-07 21:18:22 [3340] OOBELib: Validate using Driver LEID : V7{}PremiereElements-EMT[12]-Win-GM, App LEID : <blank>, SN : 971400085900480326924654
2017-02-07 21:18:22 [3340] OOBELib: Failed to get system default proxy in setProxyCredentialsForIALSession
2017-02-07 21:18:22 [3340] OOBELib: Failed to set proxy credentials for IAL session while validating serial number
2017-02-07 21:18:22 [3340] OOBELib: HTTPCommunicationAgent::processMessage is https://lm.licenses.adobe.com/aes/aes/v1/serialInfo (extURL=)
2017-02-07 21:18:24 [3340] OOBELib: HTTP Request Status code 200.
2017-02-07 21:18:24 [3340] OOBELib: HTTPCommunicationAgent- Return Code:[0] response size-[232] time taken-[1509.72]ms.
2017-02-07 21:18:24 [3340] OOBELib: Got error from server-[9].
2017-02-07 21:18:24 [3340] OOBELib: ErrDesc from server: Some unknown error has occurred. : No associated Driver LEID is present in the database..
2017-02-07 21:18:24 [3340] OOBELib: Validate Serial status-[521] took-[1511.46]ms.
2017-02-07 21:18:24 [3340] OOBELib: OOBELib IAL VSN unknown error occured
2017-02-07 21:18:24 [3340] OOBELib: OOBELib IAL ValidateSerial call has failed : 521
2017-02-07 21:18:24 [3340] OOBELib: Using Driver/ALL combination for offline/invalid SNs scenario
2017-02-07 21:18:24 [3340] OOBELib: SN validated for AAMEE mode
2017-02-07 21:18:24 [3340] OOBELib: OOBELib stat = 257
2017-02-07 21:18:24 [3340] Adobe PRTK: Failed to validate the serial number
2017-02-07 21:18:24 [3340] Adobe PRTK: Return code 14
2017-02-07 21:18:24 [3340] Adobe PRTK: *** Adobe PRTK tool END ***
Thanks Dylan
Have something to add?
