I know it's possible to filter your images by orientation e.g. portrait or landscape with the metadata search field. But is there also a way to only find landscape orientated raw-files with tiff:Orientation="1" or tiff:Orientation="3"?
Thanks in Advance
Adrian
The Any Filter plugin can do this, using this filter:
LR reads the EXIF:Orientation field into the catalog, and the filter above searches (relatively quickly) through that catalog field.
If you really want to search what's stored in the file on disk, you could use this filter:
That will go much slower, since it uses the utility ExifTool to read each file's metadata.
Thank you John! Works great!
