Hi i give some Pictures (RAW Files) Stars, but if i want export them from Lightroom CC, the Stars not more in the JPG File.
Did you include Metadata during the export?
How to export photos from Photoshop Lightroom
yes
What is your exact version of LR and your OS?
What did you use to check the stars in the jpg?
Lightroom Version 2015.8
I give the Stars with the Photo Mechanic Aplication
Lightroom CC
Sometimes i give the Stars with another Aplications ( From Ipad) Camera Connect, and then i can See the Stars in alls the Apliations, Lightroom to, but only after Export in JPG nots starn more there
Normally, LR does export the star rating in the industry-standard XMP:Rating field, and I just verified that with CC 2015.8.
The most efficient way to troubleshoot this: Select one of the problem photos in LR. Do Metadata > Save Metadata To File. Then upload the photo to Dropbox (or similar) and post the sharing link here. (Note that insert the photo directly into a forum post here can strip the photo's metadata.)
The jpg has 5 stars. Is that correct?
No this jpg has not 5 Rating stars 😞 Only RAW
They both have a rating of 5. See below.
From the jpg:
and from RAW:
I believe you, but i can not see the Stars after export in my Aplications:-(
I'm on Windows, so I can not check with the same applications you use.
I just can tell you that the RAW as well as the JPG has a rating that is visible in Windows applications that support the xmp rating, i.e. MS PhotoViewer, MS Windows OS/Explorer file properties...
I can not see the Stars after export in my Aplications:-(
Which applications are you using to view the stars of the exported photos? Mac or Windows?
Verified on Windows: Starts are exported OK.
