In film strip (Grid Mode), the images no longer have info (like case number, file type) at the top of images and the images on the strip are larger now. (Example: Cr105079, PSD). When I hover over the images information overlay appears showing info regarding images and tags appear at the bottom so no problem there. What steps do I take to restore the Cr # at the top of the images (grid mode) in the film strip? Thank you so much for your help.
Sounds like you've tripped over a bug in CC 2015.8 / OS X 10.12 that's been acknowledged by Adobe. See this post in the bug report for a workaround: Filmstrip is covering / overlapping filter- and breadcrumb bar | Photoshop Family Customer Community . Please add your me-too vote and details of your issue to that bug report to make it a little more likely it will get fixed soon.
Hit J key to toggle info display and Ctrl+J to set the options.
How to set Library view options in Lightroom
Thank you so much. I researched the link you gave me and after clicking on Window>Show Tab Bar, shutting my computer off and then back on again, the workaround did the trick.
