I'm building a game using Adobe Animate, and I want to have some 'minigame portions' within it. I'm planning to have some basic minigame functions listed below, but I am unable to find code for them anywhere. I often see these features in online Flash games, so I was wondering if there is anywhere I can get code for these features from:
- Tapping the spacebar as quickly as possible to fill up a bar (the bar will deplete over time).
- Using the cursor to touch moving objects to fill up a meter.
For the second feature, I'd like to know if there is a way to lock the player's cursor within the boundary of a Movieclip? I'm planning to have the game within a Movieclip, rather than using the whole Scene for it. Also, I'd like to know if there's a way for the moving objects within my MovieClip to disappear once they move past the boundary of my Movieclip. Is it possible to make my objects move using the Timer function? I thought of using the Timeline to make them move, but since I want the speed of the moving objects to change depending on the difficulty setting, and I want a 'random direction' element, I think using the Timer function would be more efficient.
here are some tutorials, Search results
and you can use google to search for specific snippets.
You're talking about stealing large chunks of code from other people's projects. What you should be doing instead is sitting down and figuring out every low-level step necessary to implement each minigame in your project. For example...
This is not a "feature" of Animate, it's a collection of features working in concert to create a system. For this interaction you will need to learn how to:
These are things you can ask specific questions about. Like these...
Oh god no. Animate absolutely cannot take control of the mouse pointer. That would be a nightmare vector for malware.
The Timer class is AS3 only. If you're working in a Canvas project, the underlying CreateJS library provides a global Ticker, which you can attach event listeners to. You can also run code at arbitrary intervals by using setInterval.
