Under "Process Multiple Files, " suddenly I am now unable to rename multiple files. (See Image Above). I am using the same procedure I have always used, but now am getting the error message shown. Please help!
P.S. - I also tried changing to a different Destingation Folder, but I received the same error message.
What I don't understand is that there is nothing in the drop-down menu just over:
Starting serial #: 1
Can you select an option by clicking on the small triangle on the right of the empty field?
For me, it's either 'None' or a choice of a pattern of digits or letters.
I had selected "none" from the drop-down menu in the box above Serial #. Nothing appeared in the box afterwards. I just tried it again and got the same error message.
"None" would mean that you want to copy or rename a list of files with the same file name in the same folder?
Choose the common templates so that all files are renamed with a sequential name, like 'MyPhoto0001', 'MyPhoto0002' etc.
I solved the problem by inserting "Three Digit Serial Number" in that box, which corresponds to the starting number in the box below it.
Thanks for your help!
