Please look at the attached snapshots. One is from Premiere Elements 13 and the other one is from another known video editor program. I would like to know how I can expand a video file into scenes in Premiere Elements timeline, same like the one showing on the other video editor program's timeline?
Also, right-click on the track header to the right of the video track and select a view from the Display Styles.
Switch to the "Quick" mode. You can switch back and forth as needed.
There is a reason I check this forum regularly. I keep learning new stuff! Thanks!
I have a attached a snapshot here, showing the exact location to click and change the video track display style.
The toggle's location does vary a bit, depending on which version of the program you're using.
ic. The snapshot posted above is from Adobe Premiere Elements 13.
