I have adobe x standard. trying to place electronic signature but receive an Error message - "Incorrect password." have Windows computerE
How do I correct error message, incorrect password, when trying to place electronic signature in pdf?
Hi alanl12188648,
If you have forgotten the password. Sadly, there isn't much that can be done.
You may create a new digital Id to sign a document: https://helpx.adobe.com/acrobat/using/digital-ids.html
-Tariq Dar.
That didn't answer the question.
I am also dealing with this. The password is correct. Yet it says it is not.
Exactly. Correct password, says it's not.
I have faced the same problem, I generated a key pair with a password but when I tried to sign the document (or add the certificate as default), Adobe Acrobat said that the password was incorrect, I have checked many times this password (using Keystore Explorer or Windows build-in services) and all correct.
As a variant, I can advise adding your key to the Windows key store via "certificates import Wizard" and then it will be available in the default list of certificates for sign.
