VBScript to call JavaScript
Engaged ,
Feb 08, 2017 Feb 08, 2017
See if you guys can help me:
Is there a way for a Photoshop VBScript to call a JavaScript file?
Or at least pass some user input (variable or return from function) from one script to another.
Here's what I have. This simple VBScript asks for the user to type in their name which is then created as text in the second script.
VBScript
' Ask User for input
Dim
appRef Set appRef = CreateObject( "Photoshop.Application" )
Dim askName : askName = InputBox("Enter name: ")
JavaScript
// create a document to work with
var docRef = app.documents.add(200, 100, 72, "Hello");
// Create a new art layer containing text
var artLayerRef
= docRef.artLayers.add();
artLayerRef
.kind = LayerKind.TEXT;
// Set the contents of the text layer.
var textItemRef
= artLayerRef.textItem
textItemRef
.contents = "Hello " + askName
What do I need to connect the two up?
Actions and scripting
2.6K
Guide , Feb 15, 2017 Feb 15, 2017
Adobe
Sorry.
You always asking but never give credits to your helper.
Engaged ,
Feb 09, 2017 Feb 09, 2017
Probably because that's not been pointed out to me
Whooops! My bad
Guru ,
Feb 13, 2017 Feb 13, 2017
You don't need VBS for this. JS has Prompt.
main();
function main() {
    var askName = prompt("Enter name:", "", "My script");
    // if the user hits 'Cancet', it returns null, otherwise the value of the text edit field
    if (askName != null) {
        var artLayerRef = docRef.artLayers.add();
        artLayerRef.kind = LayerKind.TEXT;
        var textItemRef = artLayerRef.textItem
        textItemRef.contents = "Hello " + askName;
— Kas
Engaged ,
Feb 14, 2017 Feb 14, 2017
Kas,
I know about JavaScript UI but... I've been having the same problems as this guy: Script won't create UI as window does not have a constructor. The problem is erratic and hard to pin down. I do NOT want to have to delete PS prefs each time.
So I was wondering if it was possible to get VBS UI to call the JavaScript. - Although I might end up doing something in HTML instead
Guru ,
Unlike InDesign, Photoshop doesn't have the 'doScript' method so, of the top of my head,  my answer is no, it's impossible. Maybe there's a workaround but I don't know about it.
In my opinion, the easiest approach, in this case, would be to translate the script from JS to VBA.
— Kas
Guide ,
Guru ,
I looked for it only in the JS reference: obviously it wasn't there. It is in the VBS reference (last time wrote in VB for Photoshop somewhere in 2004 -- that's why I didn't look here) so theoretically it should work but, for some reason, VBS-files don't appear in my scripts menu (tested in CC 2015 and 17). Also, they're unavailable via 'Browse' menu: it allows to choose only JS.
CC 2015
CC 2017
Here they give a contradictory information:
First they say: "In Windows, you can use scripting languages that support COM automation, such as VB Script."
A few lines below: "Choose File > Scripts and then select the script from the list. The scripts list includes all the script files saved with a .js or .jsx extension and saved in the Photoshop CS5/Presets/Scripts folder. To run a script saved in another location, choose File > Scripts > Browse and navigate to the script."
— Kas
