I have created a project that seemed very easy to do. My
problem is that I do not know how to export my file so that
everyone can see my project without having to purchase Captivate.
Is there a way to convert my project to a file evryone can
view?
I assume you have Captivate, in which case, select the
"Publish" button and you will be faced with a dialogue box where
you can choose the published file name, format (SWF, EXE, DOC
etc.), full screen or not and so on.
Play around to find the format that suits you best.
What you need to do is to
Publish your project to create the output files. You may
choose between .SWF or .EXE as your output that all may view. You
then make the .SWF or .EXE available to the users.
Secondly, when I publish, it creates 4 documents. The first
being the link itself (htm doc)and the other 3 are a .SWF,
skin.SWF, and standards.js file. If i click on the HTM file it
lauches my presentation. But if I send only the HTM file to
someone, they cannot view the presentation. Do I need to send all 4
documents?
One thing I didn't mention is that you might be better off by
copying those files to a server. Then simply send the link to the
HTML page. Your user clicks the link and views your Captivate.
If you can do this it will likely save you and the recipient
some grief.
