Hola, me gustaria saber como puedo exportar filtros desde el canvas a html5.
Cuando exporto texto con sombras o brillo, estos desaparecen en html5.
create a new html5 document.
add text to the stage
while that text is still selected, in the properties panel, add a drop shadow
do that appear successful?
test does the drop shadow appear in your browser?
just publish (file>publish) your html5 project, don't export it.
It's not working
* Quality, Knockout and Inner glow of Glow Filter no se admiten en el documento HTML5 Canvas y se eliminaron en una instancia de Movieclip
do you have any problem with drop shadow?
Yes! its not working in HTML5
I do not know why, but it works now, thank you very much!
I one more question, i have the shame problem when im trying to change the colour to an object, i see it in animate but not when i publish to html5
are you using the latest version of animate:
Yes, the last one!!
You can do it?
do you mean if you edit/change something on stage using the toolbar and then test, you fail to see the changes made?
if so, are you overwriting your html when publishing:
Yes I always overwrite the html, yes is right, I try to change something to an other color, I see it on stage, but then in html5 no.
