I'm trying to get the name of the font used in the text within a textbox using javascript, however all the help articles I see don't appear to work - I suspect that the functionality has been renamed or removed in recent versions of InDesign. (I'm using CC 2017.) Can anyone provide a code snippet that will work?
I've tried the following, based on another post:
var docPages = app.activeDocument.pages;
var numPages = docPages.length;
for (i = 0; i < numPages; i++) {
pageItems = docPages.allPageItems;
for (j = 0; j < pageItems.length; j++) {
if currentItem instanceof TextFrame) {
// try to get font used in TextFrame
fontName = pageItems
.paragraphs[0].fontStyle; // DOESN'T WORK }
I don't see any reference to anything that lets me query the contents of the textbox on the TextBox API page.
Adobe InDesign CS6 (8.0) Object Model JS: TextBox
Any advice would be greatly appreciated!
Figured this out now:
currentItem = pageItems
; if (currentItem instanceof TextFrame) {
if (currentItem.contents.length > 0) {
$.writeln(currentItem.paragraphs[0].appliedFont.name);
the objects textFrame and textBox are two very different objects.
textBox is one of the formField objects and has very limited formatting options.
So textFrame is obviously the one you were looking for.
However the applied font you are reading out with paragraphs[0].appliedFont.name will only reflect the formatting of the first character in the first paragraph of the frame (if a paragraph is existing at all).
To get the appliedFont information for the whole text frame you better hunt for textStyleRanges and inspect them.
See the following example:
Your code would one give one result that is reflecting the formatting of the first character:
Mistral Regular
Assume the text frame shown above is selected
and you are working with textStyleRanges the result would be more accurat:
var uniqueNamesArray = [];
var orderInAppearanceNamesArray = [];
var usedFontNames = [];
var textFrame = app.selection[0];
var x;
var textStyleRangesArray = textFrame.texts[0].textStyleRanges.everyItem().getElements();
for(var n=0;n<textStyleRangesArray.length;n++)
var fontName = textStyleRangesArray
.appliedFont.name; // Do a unique list:
uniqueNamesArray[fontName] = fontName;
= fontName; };
// Reading out the uniqueNamesArray:
$.writeln("uniqueNamesArray:");
for(x in uniqueNamesArray)
$.writeln(x);
// Reading out the orderInAppearanceNamesArray:
$.writeln("\r"+"orderInAppearanceNamesArray:");
for(var n=0;n<orderInAppearanceNamesArray.length;n++)
$.writeln(n+"\t"+orderInAppearanceNamesArray
The result will be:
uniqueNamesArray:
Mistral Regular
Adobe Garamond Pro Regular
Minion Pro Regular
Verdana Bold
0 Mistral Regular
1 Adobe Garamond Pro Regular
2 Minion Pro Regular
3 Verdana Bold
4 Minion Pro Regular
5 Mistral Regular
6 Minion Pro Regular
And then we have the collection: document.fonts
var docFonts = app.documents[0].fonts.everyItem().getElements();
for(var n=0;n<docFonts.length;n++)
$.writeln(n+"\t"+docFonts
.name) };
That will give you also the fonts used in empty text frames, in fact the font used with the single insertion point of an otherwise empty story.
I added an empty text frame to the document and formatted it with a character style that is using another font, Arno Pro:
So the result with my snippet using document.fonts will be:
0 Arno Pro Regular
1 Verdana Bold
3 Adobe Garamond Pro Regular
4 Mistral Regular
Uwe
