Windows 10, Vis Tablet
Solutions I've tried:
Restarted computer
uninistalled/reinstalled Photoshop
Uninstalled/reinstalled pad driver
Checked settings, all in order
Plugged pad into different USB port
Restarted computer several times.
Pressure was working just last night, but when I got up this morning, it draws at the same opacity and size regardless of my settings.
So to flesh out the problem, photoshop is not recognizing pen pressure when I try to draw with the pad. Shape Dynamics are set to pen pressure, i've selected the options on top to "always use pressure for size". In the pad configuration, the pressure works in its own program to test that it is working, but photoshop does not recognize it. Widows did update last night after I went to bed, but I can't understand why a windows update would make it impossible to use my pen-pad in photoshop...
I've tried searching online for help, but almost no one uses a vis tablet, so I am at a complete loss.
[Moved from non-technical Forum Lounge to specific Program forum... Mod]
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
The latest version of photoshop use INK API if brush dynamics has yellow triangle try adding the config preference file to your phottoshop preferences to use Wintab Api do a search on using wintab api.
What version of Photoshop and which API is the tablet's driver using Wintab or INK?
It is the latest version of Photoshop, and so far as the API, i am uncertain how to check what it is using in order to answer that.
That seems to have done it. This was very helpful, thank you
You've told me something there JJ. That you might be able to force the WinTab API even with tablets that don't have an option to turn off Windows Ink. VisTablet is also new to me. There are certainly a lot of non Wacom options nowadays, and I am frankly a bit surprised this thread has had a happy ending. Thanks again for the new angle on WinTab tip.
