Hi, hope some one has a solution..
Aim - resize content to snap to a guide without changing aspect ratio
Problem - Using the shift constraint or linking Width/Height the snap to guide function doesn't work??
Can anyone help Please........
That is what I wrote you seem to want to double constrain transform you want it constrained transform to snap to guides and to constrain the transform aspect ratio to the current aspect ratio. I believe you can not do that you may move the transform to snap coroners to one or two guide line then constrain the transforms aspect ratio. I do not think it is possible to have two constraints imposed on transform at once. It like ask you to pat your head with one hand and rub your stomach in a circle
...Copy link to clipboard
It seems to me you want to constrain, constrain to snap to. I think you need to do that in two steps. Move the object transform till it snaps to your guides then press and hold shift and drag corner to not snapped to a guide
Thanks, but Iv'e done that, but when I shift drag to resize and maintain the ratio, the guid snap doesn't snap. The snap to guide works fine when simple resizing, but I want to maintain the aspect of image.
Any other ideas...
That is what I wrote you seem to want to double constrain transform you want it constrained transform to snap to guides and to constrain the transform aspect ratio to the current aspect ratio. I believe you can not do that you may move the transform to snap coroners to one or two guide line then constrain the transforms aspect ratio. I do not think it is possible to have two constraints imposed on transform at once. It like ask you to pat your head with one hand and rub your stomach in a circle with your other hand while one of your hands are tied behind your back.
Thanks JJMack, that makes it very clear, cheers. I'll have to re think my approach.
