Hey there, I recently got this probblem and i dont know how to fix it, it happend before but i dont know what i did to remove it but umm
flash for some reason now, no matter what audio i import it always lowers in the pitch of it? like the audio is extreamly deep,
open your audio in audtion and export with a compatible sample rate and bitrate, Audio quality and bitrate in Flash AS3 web apps – Audior
does it have to be audition? i dont have that, and do i really need todo all of that? this glitch thing for the lower pitch is a new thing to me, its never happend before?
What sound editor software do you have? Whatever it is, open the sound file and look for an option where you change the sound to be 16 bit, 44.1 kHz. Then Save As to a new WAV file, and import that into the FLA.
What sample rate and codec were the WAV files saved with?
I always do " Wav ( microsoft ) signed 16-bit pcm " when expoting out of audacity, always worked before?
Check what sample rate you have it set to, and make it be 44.1 kHz.
how do i check that? and how do i set it to that? i use audacity though
when saving/exporting you should the option to select bitrate and sample rate.
there is no option to check in audacity, here : Imgur: The most awesome images on the Internet
and it says that its 44 in flash though....
In Audacity the main editor window has Project Rate in the lower left. That's where you would set it to be 44100. Which it looks like you have done.
Are you able to upload an example sound somewhere, so I can see if there are any other odd things about it, or to see if it changes pitch when I import it?
Does it play back lower pitched both in the IDE and when published?
