Hello,
I use After Effects on macOS Sierra. My Audio-hardware is a MOTU 24 Ao (a soundcard offering 24 analogue outputs).
AE shows the MOTU 24Ao in the preferences and also all 24 channels. Due to our studio I use channels 12 and 13 for stereo-output.
Whenever I close and re-open AE again, it looses my preferences and switches back to channels 1 and 2, so I have to adjust it again.
This did not occur on macOS El Capitan or on an earlier version of AE. I re-installed the whole system 3 weeks ago.
I know this is a rare constellation of software / hardware / preferences, but maybe someone has an idea / solution nevertheless?
I found nothing in the forums.
Steffen (Berlin)
__________________________
MacBook Pro (late 2013)
macOS Sierra (10.12.2, latest)
AE-Version 14.0.5.1 (latest)
MOTU (Driver 2.0+71418 Firmware 1.2.8+780 - both latest)
There was a bug with preferences that was fixed in this week's update to AE (version 14.1.0). Try it and let us know how it works for you.
Hi, thanks for your reply.
Best, Steffen.
Well, darn.
I'd suggest filing a bug report to let them know about your setup and issues.
Thanks, Szalam. I just filled a bug report.
Hi NUMOON,
Thank you SO much for filing that bug report. We appreciate it.
Did you try with a brand new project?
Cheers,
Kevin
YOU GUYS ROCK! Thank you for fixing the Audio 1 / 2 Channel Error and scratchy audio at 44.1kHz in the latest update! I was pulling my hair out!
B
Woah, I spoke too soon. I updated everything and it worked, then I opened Premiere while AE was open and when I switched back to AE, the audio glitch came back. This time, Right channel only, unable to select the other channel and the scratchiness of the audio was back...
Dang bryantcoffey! Sorry to hear that. Can you file a bug report? Here is the link.
Kevin
Hi NUMOON,
What did you end up doing to work around this issue? Did you downgrade your OS? Please let us know. Thanks again for filing that bug.
Kevin
