Steps to update java for Cold Fusion 11 32 bit
Feb 02, 2017 Feb 02, 2017
Is there a document that provides the detailed steps to update the Cold Fusion 11 java engine?
Also, where would one go to obtain the appropriate Java engine for Cold Fusion 11 32 bit?
Mike
1.5K
Advocate ,
Feb 03, 2017 Feb 03, 2017
Adobe blogged about this a couple of years back - you can find it here: How to change/upgrade JDK version of ColdFusion server » Adobe ColdFusion Blog
Feb 07, 2017 Feb 07, 2017
The highest Java build number for ColdFusion 11 is 1.8.0_25. So you should install the 32-bit version of the Java SE Development Kit 8u25 from the JDK archive.
The steps:
1) On the download page, click to 'Accept License Agreement'. (I assume you have Windows). Download the 32-bit JDK file. It is the file named jdk-8u25-windows-i586.exe.
2) Launch the executable, accepting the default settings during installation. The JDK should then be installed in: C:\Program Files\Java\jdk1.8.0_25.
3) Open the ColdFusion Administrator. Go to the 'Java and JVM' page. Click on Browse Server to select the new value for the Java Virtual Machine Path . You could, alternatively, just type it in. It should be C:\Program Files\Java\jdk1.8.0_25\jre.
Press the button to submit the change.
If you are running Enterprise ColdFusion and have multiple ColdFusion instances, then you should make this change in the ColdFusion Administrator of every instance.
4) Stop and restart ColdFusion. (Do this for every ColdFusion instance, if running Enterprise ColdFusion).
In the Cold Fusion Administrator, the path for the JVM show D;\ColdfFusion11\jre
There is no version number in the path.
Mike
Did you install the JDK? Did you do any of the things @Haxtbh and I suggested?
Of course, there isn't. That is what you have to change.
Feb 08, 2017 Feb 08, 2017
I have not installed the new version yet.
I originally install Cold Fusion 11.
Mike
Will the install have the version in the folder name or can I just user the same as the original install (D:\ColdfFusion11\jre)?
Mike
Guide ,
You could try this:
Regards, Carl.
Feb 09, 2017 Feb 09, 2017
You have to install a new version of Java, not of Coldfusion.
Feb 10, 2017 Feb 10, 2017
Using the command in the cmd window, the version is 1.7.0_51.
The version number is not in the Cold Fusion 11 administrator text box.
Mike
Feb 11, 2017 Feb 11, 2017
The first thing I would suggest is that you update ColdFusion 11. To do this, open the ColdFusion Administrator and scroll to the update section at the bottom: Server Update > Updates.
Click on Check for Updates. As the updates are cumulative, you will need to install only the latest update. This is currently update 11.
After performing the update, run the CMD command again. What is the Java version then?
Guide ,
Feb 12, 2017 Feb 12, 2017
Hi Mike,
What displays in CFadmin > Server Settings > Settings Summary for values relating to Java?
EG:
Java Version 1.8.0_111
Java Vendor Oracle Corporation
Java Home C:\Program Files\Java\jdk1.8.0_111\jre
Java VM Specification Version 1.8
Java VM Specification Vendor Oracle Corporation
Java VM Specification Name Java Virtual Machine Specification
Java VM Version 25.111-b14
Java VM Vendor Oracle Corporation
Java VM Name Java HotSpot(TM) 64-Bit Server VM
Java Specification Version 1.8
Java Specification Vendor Oracle Corporation
HTH, Carl.
Feb 28, 2017 Feb 28, 2017
It looks like the Java version has not been changed.
After installing Update 11, the following is the information:
ColdFusion 11 Update 11
Update Level: 11
Update Type: General
Install Date: Mon, 27 Feb 2017 05:32:40 -0700
Update Description:
ColdFusion 11 Update 11.
ColdFusion 11 Update 11 includes bug fixes related to Security, Language, Administrator, Document Management, AJAX, and various other areas.
For details, click on the "Read More" link below.
Java Version  1.7.0_51
Java Default Locale  en_US
Java VM Specification Version  1.7
Java VM Version  24.51-b03
Java Specification Version  1.7
Mike
No problem. You can now install the JDK of Java 8. Follow the steps in my post of Feb 7, 2017 12:19 PM.
Documentation
