Heya
"Generating outside the project or to the SSL"
I'm guessing you are asking if my output folder is the
WebHelp folder found inside the !SSL! folder? If so, yes I'm
generating to that folder.
Okay, so I see what you are referring to here. Indeed
RoboHelp does seem to be flipping the forward slashes to backward
slashes when I look at the TOC entry later.
Okay, finally the fog is clearing. After I generated and was
looking, I was opening in FireFox and hovering the link. I was
seeing forward slashes. Somehow spaced off the fact that it was
explicitly looking for the folder to be present in the WebHelp
folder. Hmmmm, how to overcome.
I've got an idea here. What if a redirect page were used?
Simply configure the redirect to point to the relative path and
point the TOC entry to the redirect?
Pondering out loud here.
Out of curiosity, how does one normally go about creating
project to project links in your normal Merged WebHelp scenario? I
figured you had that all sorted as that's the way you fly there,
no?
Cheers and thanks for keeping an old dog honest... Rick
