I'm importing an illustrator file into AE, then creating shapes from vector layers. Some of the shapes, the bounding box fits right to, but some the bounding box fits the composition. Any ideas why this is?
Thanks for any help.
Best,
Jeremy
Short answer:
you got opacity other than "100%" or blend modes other than "Normal" in one of the objects. change it to the default and try again.
Long answer:
changing the opacity or blend mode other than the default to any object in your illustrator file will cause the "create shapes from vector layer" to behave in the following manner: your shape layer will have an additional group in the shape hierarchy that will contain paths and merge operation that constitute a transparent Ai artboard. it's
...Copy link to clipboard
Short answer:
Long answer:
changing the opacity or blend mode other than the default to any object in your illustrator file will cause the "create shapes from vector layer" to behave in the following manner: your shape layer will have an additional group in the shape hierarchy that will contain paths and merge operation that constitute a transparent Ai artboard. it's very annoying.
it could look like something like this if you work in an HD Preset.
BTW HD preset gives you 2 artboards.. it's actually a good thing:Re: AI (illustrator) layers not showing up in AE (after effects) CC 2014 )
here is the shape hierarchy comparison of Layer 1 that is normal and Layer 2 that has 50% opacity:
as you can see the artboard is here as a group with 3 paths and there is an additional merge path operation to the content of the shape.
What to do?
One last thing:
the only reason to ever use the "create shapes from vector layers" feature is if you are planning to manipulate the actual path of the shapes, or use any of the shape operators (repeater for example) or maybe extrude them through the C4D renderer. that's basically it. shape layers are complicated. they are always continuously rasterized and each path of your illustrator artwork will get it's own shape group hierarchy - it's get's messy very fast. so if you are not planning to do that, you should just let them be pixel layers. if you need vector functionality, you can press the continuously rasterize switch.
Hello Roei,
Thanks so much for the thorough explanation. That was the problem. I didn't even think to check that. I checked everything else under the sun though. It makes sense. Ok, let me go share the good news.
Best,
Jeremy
You're welcome Jeremy. this issue is troubling users from time to time and the information is here in the forums if you are looking hard enough, help others find this quickly by marking the response as correct.
I just read the whole answer. It's so helpful. I am facing similar trouble. Thank you so much.
