Setting Scale Corners in a script
Feb 10, 2017 Feb 10, 2017
I'm writing a script to fit an object into a specific sized box. I'm using:
artwork[0].resize(scale, scale ,1,1,1,1,scale);
in order to change the size. Everything seems to be working fine except if I have the "Scale Corners" check box in the Transform palette turned off. Then, of course, it doesn't scale the corners!
I can't figure out of there is a way to either, override that in the script or change the setting and then change it back when its done.
I tried:
getBooleanPreference("Scale Corners");
to see if I could get to it that way, but it doesn't match up with what is shown as selected!
Any ideas?
Scripting
765
Enthusiast , Feb 11, 2017 Feb 11, 2017
Sorry, I misunderstand you before. Well, seems like we have to call an action.
var actionStr =
['/version 3',
'/name [1 73]',
'/actionCount 1',
'/action-1 {',
'    /name [ 12 7363616c65436f726e657273]',
'    /eventCount 1',
'    /event-1 {',
'        /internalName (ai_liveshapes)',
'        /parameterCount 1',
'        /parameter-1 {',
'            /key 1933800046',
'            /type (boolean)',
'            /value 1',
'}'].join('');
createAction(actionStr, 's');
app.doScript('scaleCorners'
Adobe
Enthusiast ,
Hi, to turn on the check box in script:
app.preferences.setBooleanPreference('scaleLineWeight', 1);
Thanks @moluapple but that's not quite what I'm after. It's scale corners that I'm looking for.
Here's a pic showing what's going on! When the center logo is resized, the top right logo is what happens. And the bottom right is what I want. The check box I want to switch is the one bottom left in the transform panel. (Scale Corners)
I've now had a quick try at "app.preferences.setBooleanPreference('scaleCorners', 1);" (thanks for the suggestion) but that still doesn't seem to do it!
Enthusiast ,
var actionStr =
['/version 3',
'/name [1 73]',
'/actionCount 1',
'/action-1 {',
'    /eventCount 1',
'    /event-1 {',
'        /parameter-1 {',
'            /key 1933800046',
'            /type (boolean)',
'            /value 1',
'}'].join('');
app.doScript('scaleCorners', 's');
app.unloadAction('s','');
function createAction (str, set) {
    var f = File(set + '.aia');
    f.open('w');
    f.write(str);
    f.close();
    app.loadAction(f);
    f.remove();
Hi moluapple​,
only one note (or better addition):
line #14 in your Code is the important line.
     '               /value 1', // value 0 for uncheck the option Scale Corners
Have fun
Enthusiast ,
Of cause you are right.
Also note I had deleted some parts, only left the core parts of the .aia file, so now is the structure(1st line + 3 + 3 + 3 + 3 + end lines):
  • name
  • count
  • action/event/parameter details
