Hi Jan808
Based on what you have said, it would appear my colleague
Peter was spot on in his assessment. What was totally throwing me
was the fact you said you wanted to "Edit the graphic in RoboHelp".
Which seems to imply you want to open the image inside an image
editor to change the way it looks. Perhaps change the colors around
or otherwise make the image appear differently when you are
finished.
I think what is further confusing the issue (at least for my
reading and understanding of the question) is that you said you
used a "Tab Generator" to create things. This typically means that
you used some sort of application that spits out a menu that may be
used. These normally consist of several different images and lots
of JavaScript to make the menus work as you want. That's why I was
hesitant to accept a simple Image Map was what you needed.
So it would seem that you simply have a single image on a
HTML page and want it to do different things when you click
different areas. Right? Assuming that's the case, you need to
listen to Peter. An image map is the way to fly and I apologize for
muddying the waters with my babbling.
Happy Wednesday all! Rick
