so, i have 8gb RAM and after effects for some reason is eating up everything.
im using CC 2014 and i dont think it was supposed to use all the RAM i have considering it says in Adobe site that 4GB is the minimum and 8GB is the requirement.
If 8gb is the requirement, i guess it should have no lag or anything if im using 7gb. however i cant preview anything due to lag. today i created a new sequence and put a video in it, and i couldnt preview it because it would be in slow motion on something. i didnt even add any effects or anything.
i already tried increasing the memory reserved for AE as well as increasing cache size to 100gb in my HD. i also tried to enable CUDA but for some reason it said my graphic card does not have cuda or something ( which it does )
can anyone help me?
Nobody can tell you anything without exact system info or other technical details like exact comp and preview settings, kinds of footage and so on.
Mylenium
i3 4170 3.7ghz -> processor
GTX 750Ti -> graphic card
2x4gb Hyperx Fury -> RAM
Windows 7 64 bits
thats my system information. my preview settings is 1/4 quality, using 1494mb ( max ) for Texture Memory. Ray tracing is GPU (used to be CPU but wasnt work either)
the memory settings i use is : 1,5gb reserved for other aplications and 6,4gb shared by After Effects and Premiere.
the footage i'm currently using is a .mov 10 second movie. however i tried using .mp4 .avi and many others, but the lag persists.
thanks
Check your graphics driver settings. I vaguely remeber the 750 Ti always causing some weird screen refresh issue that drags down overall preview speeds. Perhaps you have enabled forced V-sync or use a specific optimized game preset.
Mylenium
Not really.
It may be the minimum requirement to run it, but you need more RAM than that to run it comfortably.
What are the rest of your system specs? That will likely also be a factor.
Windows 7 64 bits
thats my system specs..
thanks
