there is any way to change text between brackets (there are hundred of them) by one command?
Hi
See above Obi-wan's answer, this is what you need.
Note OWK did translate bracket as [ ]
If you meant ( ), then use \(\K.+?(?=\))
The Forum Lounge is not for technical help, please provide the name of the program you are using so your message may be moved to the correct program forum
I'm working with Indesign
To select text between brackets:
\[\K.+?(?=\])
Moved from the non-technical Lounge to InDesign by moderator
Are you wanting to change the text to something specific or change the formatting of the text? And do the brackets remain or do they need to leave. The second question would determine if a find/change would be better for you or if you should build it into a style.
I would like to change format of the text between the brackets (I want to keep the brackets)
Hi
Great!
Thanks a lot!!!
Thanks but credit should go to our Jedi...
De rien, Vincent! 😉
THANK YOU!
