Text Disappears using Publish Online
Windows, InDesign 2017.0 Release (12.0.0.81 x64 Build)
All attempts to use the Publish Online feature result in disappearing text. Images appear, but text does not. The text appears fine when exporting to PDF.
After reading through the community forum, I have tried various methods.
To recreate the steps:
Can anyone advise as to how to create a document where the text appears when using the Publish Online feature of InDesign on a Windows system?
How does the print preview look like in InDesign?
Did you apply any form of transparency as it is not supported in HTML5.
The Print Preview looks fine. No transparencies. If I create a new document with all the defaults, select the text tool, enter some text, Publish Online - I can see the text in the preview, but not in the browser.
Hi Linne,
what is your browser you are using for testing the published document online?
The "text" in an publish online document is converted to SVG shapes and is not live HTML text.
Does your browser support SVG?
Please post a link to the published document where you cannot see the text.
Maybe others can see the "text" when using different browsers or different browser settings.
And: Can you provide a sample InDesign document for testing?
Also the exported PDF.
Perhaps you could zip both files and upload the zip to your Dropbox account ( or a similar service ) and share the download link with us.
Uwe
I'm testing with both Chrome and Edge browsers.
Sample of Publish Online - published
https://indd.adobe.com/view/819cabe9-8648-4967-932c-bd61668ceadc
DropBox Link (Zip file with InDesign file and exported PDF)
https://www.dropbox.com/s/souwr1clbsipkuh/InDesignCC2017-PublishOnline-TextTest.zip?dl=0
Thank you for your help here.
Hi Linne,
I tested your link to the published document:
There is no text visible ( Firefox browser on OSX 10.10.5 ).
And I think everything is ok with your document.
Opened and published your document with my InDesign CC 2017 v12.0.0.81 on OSX 10.10.5:
https://indd.adobe.com/view/5cda19b8-3bcf-4cd5-a0f8-3c1fbda8ab93
Clearly the text is visible.
I downloaded your publish online document page using the browser's Save command and inspected the code of your publication.html file. The whole SVG section is missing. So I suspect that something's wrong with your SVG export module of InDesign.
Maybe something on your system is distracting your SVG module.
Do you have any browsers open when publishing online?
Are some browser extensions active when publishing online?
First I would try again without a browser open.
Uwe
Thank you for running that test for me. I too can see the text at the link you created.
I rebooted the system, opened the file in InDesign with no other applications or browsers running, did Publish Online and no text.
What is the "SVG export module of InDesign?" How do I check for that? a plugin? Something I didn't install? Suggestions?
Linne wrote
… What is the "SVG export module of InDesign?" How do I check for that? a plugin? Something I didn't install? Suggestions?
I mean InDesign's function to render text as SVG shapes when output with Publish Online.
All functionality with InDesign is stored in an internal plug-in infrastructure around some core functions that hold the plug-ins together.
Could also something with your plug-in that does Publish Online…
What can you do?
Uninstall and reinstall InDesign perhaps?
Uwe
I uninstalled and reinstalled InDesign. Problem persists. Not sure what to do... Is there some way to reinstall the internal plug-in infrastructure for the core functions?
Sorry. I'm running out of ideas…
Hm. Uninstalling and reinstalling the CC Desktop app would be my next guess.
But before doing this, let's see if Adobe staff is stopping by.
Uwe
I spoke with Technical Support and neither the tech nor his supervisor were familiar with the SVG export module or why that would be a problem. I waited their suggested 3 hours to try again... and I still no text appeared using the Publish Online feature. Looks like my only remaining option is to uninstall Adobe Creative Cloud. <insert deep heavy sigh>
Thank you for your support out here and wish me luck!
Dear Linne!
I have the same problem... Did you found solution?
Here a comparison of code with both publication.html files.
Left is mine, right is yours where the whole <svg … /svg> section is missing:
Note: The value of class for "_idContainer000" is different from yours, because I'm on a German inDesign on OSX 10.10.5.
It says "Einfacher-Textrahmen" wheras yours is saying "Basic-Text-Frame". But that's not the culprit, I think.
Both publish online documents are showing the same thumbnails preview where the text is visible:
Uwe
