Locked
HUGE PROBLEM!!! with: Some files on the server may be missing or incorrect. Clear browser cache and try again. If the problem persists please contact website author
Dec 31, 2016 Dec 31, 2016
I tried uploading with ftp and export as html. It just doesn't wanna vanish away, I even tried deleting this script
<script type="text/javascript">
   window.Muse.assets.check=function(d){if(!window.Muse.assets.checked){window.Muse.assets.checked=!0;var b={},c=function(a,b){if(window.getComputedStyle){var c=window.getComputedStyle(a,null);return c&&c.getPropertyValue(b)||c&&c||""}if(document.documentElement.currentStyle)return(c=a.currentStyle)&&c||a.style&&a.style||"";return""},a=function(a){if(a.match(/^rgb/))return a=a.replace(/\s+/g,"").match(/([\d\,]+)/gi)[0].split(","),(parseInt(a[0])<<16)+(parseInt(a[1])<<8)+parseInt(a[2]);if(a.match(/^\#/))return parseInt(a.substr(1),
16);return 0},g=function(g){for(var f=document.getElementsByTagName("link"),h=0;h<f.length;h++)if("text/css"==f.type){var i=(f.href||"").match(/\/?css\/([\w\-]+\.css)\?crc=(\d+)/);if(!i||!i[1]||!i[2])break;b[i[1]]=i[2]}f=document.createElement("div");f.className="version";f.style.cssText="display:none; width:1px; height:1px;";document.getElementsByTagName("body")[0].appendChild(f);for(h=0;h<Muse.assets.required.length;){var i=Muse.assets.required,l=i.match(/([\w\-\.]+)\.(\w+)$/),k=l&&l[1]?
l[1]:null,l=l&&l[2]?l[2]:null;switch(l.toLowerCase()){case "css":k=k.replace(/\W/gi,"_").replace(/^([^a-z])/gi,"_$1");f.className+=" "+k;k=a(c(f,"color"));l=a(c(f,"backgroundColor"));k!=0||l!=0?(Muse.assets.required.splice(h,1),"undefined"!=typeof b&&(k!=b>>>24||l!=(b&16777215))&&Muse.assets.outOfDate.push(i)):h++;f.className="version";break;case "js":h++;break;default:throw Error("Unsupported file type: "+l);}}d?d().jquery!="1.8.3"&&Muse.assets.outOfDate.push("jquery-1.8.3.min.js"):Muse.assets.required.push("jquery-1.8.3.min.js");
f.parentNode.removeChild(f);if(Muse.assets.outOfDate.length||Muse.assets.required.length)f="Some files on the server may be missing or incorrect. Clear browser cache and try again. If the problem persists please contact website author.",g&&Muse.assets.outOfDate.length&&(f+="\nOut of date: "+Muse.assets.outOfDate.join(",")),g&&Muse.assets.required.length&&(f+="\nMissing: "+Muse.assets.required.join(",")),alert(f)};location&&location.search&&location.search.match&&location.search.match(/muse_debug/gi)?setTimeout(function(){g(!0)},5E3):g()}};
var muse_init=function(){require.config({baseUrl:""});require(["jquery","museutils","whatinput","jquery.watch","jquery.museresponsive"],function(d){var $ = d;$(document).ready(function(){try{
window.Muse.assets.check($);/* body */
Muse.Utils.transformMarkupToFixBrowserProblemsPreInit();/* body */
Muse.Utils.prepHyperlinks(true);/* body */
Muse.Utils.fullPage('#page');/* 100% height page */
$( '.breakpoint' ).registerBreakpoint();/* Register breakpoints */
Muse.Utils.transformMarkupToFixBrowserProblems();/* body */
}catch(b){if(b&&"function"==typeof b.notify?b.notify():Muse.Assert.fail("Error calling selector function: "+b),false)throw b;}})})};
</script>
But then it won't display the images. :c please help
4.4K
Adobe Employee , Feb 13, 2017 Feb 13, 2017
Please install the latest release which includes fix for this issue :
Muse 2017.0.2 is now live
Sanjit
Contributor ,
Jan 01, 2017 Jan 01, 2017
I found this article although nothing on it has helped me and all my websites.
It's a massive failure for Muse and I'm ready to jump ship.
I have too many websites affected by this, and other errors every time there is an update.
So frustrated with Muse right now. They are actually costing me money at this point.
https://helpx.adobe.com/muse/kb/files-on-server-missing-incorrect.html
all my websites from 2k16 were affected by this...They really need to fix/remove that script.
Jan 02, 2017 Jan 02, 2017
I had same problem as well.. not sure why
Go into FTP and remove entire folder where the site is uploaded to and perform a complete re-upload. Also check the permissions on the folder are 777
Engaged ,
This has happened to me several times before. Sometimes it was due to an incomplete upload of files to the FTP. What I have done in the past is delete EVERYTHING off my server via FTP and refresh it. Then, when exporting, make sure all files are there before upload. Then re-upload your site. Keep in mind that Muse doesn't optimize your images, so if you have large images, when they are still uploading you might get this message.
i deleted everything off my ftp and upload it through muse butt i still have that problem.
Engaged ,
Do you have a test URL you can share?
My best,
Justin
i don't have a test url but i can upload my whole site if you want because it's not that big.
But when i was looking at the "source" with inspect element, I saw this http://i.imgur.com/OqnXslY.png
Delete everything again and then do an export to your desktop then use a ftp client to manually upload it to the remote directory. Make sure to delete any .htaccess and php.ini files in your public_html tree
I did exactly what you said m8 but of course nothing changed.
You shouldn't have to delete anything. Just clear your browser history.
Jan 03, 2017 Jan 03, 2017
nah it's a muse problem.
I did clear my browser cache multiple times and even my friends did the same thing.
But nothing has changed.
Strange, clearing the browser history worked every time for me. Do you have a link we can see?
If it is a Muse issue then anyone that goes to it should get the error.
I had it listed above. But there you go http://kami.cf
Engaged ,
No issues here.
What do you mean?
Engaged ,
I don't get the error you describe when viewing that URL.
Sounds like a caching error on your end?
i have deleted my cache but it still pops up...     Imgur
After deleting your cache you must actually shut down the browser. Also try deleting your cache before you even go to that page.
Open Browser
Delete All Cache/History
Shut down/close browser
Reopen browser
Go to site
i did it. Cleared cache and history, closed browser, went to my webiste.....Annnnnnnd same error.
tried it with microsoft edge and chrome.
Engaged ,
If it makes you feel any better, I had the same issue today on business catalyst. We had to delete all files and then re-upload from Muse and select "all files". The tech said that he cleared the server cache. I asked how to clear cache in BC...he said only they could do it.
damn 😕
Engaged ,
Are you using Business Catalyst?
no i'm not.
