Thanks Rick!
I am actually Flashhelp (not my choice! but for right now, I
don't have a web skin so this is what I am somewhat stuck with).
THe FlashHelp layout properties has the same field, but there is a
"Project Name" field before that.
So- at this point I have tried the following:
Navigate to my desired output directory.
Enter the filename I want at the end of the path
<filename>.htm
Upon generation, the output creates that .htm as a directory,
not as a file. The startpage file appears to match the project
name.
So- thinking the start page might somehow access the project
name, I changed the project name to the start page I wanted.
The startpage also matches the original directory name of
this project. So I'll try that next.
Since the output default filename appears to match the
Project Name I had originally assigned to this project, I changed
the project name, but that had no
