$.stack is not a string
Feb 14, 2017 Feb 14, 2017
ESTK and FDK documentation and even typeof claims that $.stack is a string. If it is printed with $.writeline it behaves as such and creates multiple lines.
I want to build a function which can be called in any routine and will then indicate the calling level by indentation and the name of the function.
For that puprose I wanted to split the 'string' into an array, the length of which indicating the nesting level of the function in question.
But it turns out that $.stack can not be handled as a string:
function ZTrace () {
// $.stack is not a string - what is it?
var level, aStack = [], s1Stack, s2Stack;
  s1Stack = toHex($.stack);
  $.writeln (s1Stack);                    // see what it looks like
  s2Stack = $.stack.toString();           // sStack behaves as stack
  aStack = s2Stack.split (hex2a("829a")); // does not split
  level = aStack.length;                  // always 1
  $.writeln (aStack[0]);                  // always full stack
  $.writeln (aStack[1]);                  // undefined
} // --- end ZTrace
function toHex(str) {
    var hex = '';
    for(var i=0;i<str.length;i++) {
        hex += ''+str.charCodeAt(i).toString(16);
    return hex;
function hex2a(hexx) {
// http://stackoverflow.com/questions/3745666/how-to-convert-from-hex-to-ascii-in-javascript
// hex2a('32343630'); // returns '2460'
    var hex = hexx.toString();//force conversion
    var str = '';
    for (var i = 0; i < hex.length; i += 2)
        str += String.fromCharCode(parseInt(hex.substr(i, 2), 16));
    return str;
For example, in a nested function calling ZTrace () will create a stack like this
[ZTrace-test.jsx]
Level_0()
Level_1()
Level_2()
Level_3()
ZTrace()
But the line 05 creates (here both in hex and interpreted):
5b5a54726163652e6a73785da4c6576656c5f302829a4c6576656c5f312829a4c6576656c5f322829a4c6576656c5f332829a5a54726163652829a
[ Z T r a c e . j s x ] ¤ Æ W f u Å ó ??????L e v e l _ 1 ( ) ¤ Æ W f V Å ó ??????L e v e l _ 3 ( ) ¥ ¥ G ????6 R ????
Now, of what type is $.stack?
Scripting
420
Engaged , Feb 14, 2017 Feb 14, 2017
Hi Klaus,
$.stack is a string
$.writeln(typeof($.stack)) prints "string"
This
aStack = s2Stack.split ("\n");
does exactly, what I expected. I get an Array of lines, and the following lines of code deliver the expected results.
Last item in Array is an empty string, so level is aStack.length - 1 and perhaps -1 for the Name of the script file.
Not sure why you are doing this hex stuff.
Engaged ,
Hi Klaus,
$.stack is a string
This
Not sure why you are doing this hex stuff. I think this is not necessary.
In your case hex2a allways delivers an empty string, and this is why aStack.length is always 1.
hope this helps
Markus
Engaged ,
BTW:
str += String.fromCharCode(hex.substr(i, 2));
always delivers two not visible characters for "829a" assuming these two characters are not defined as charater within Unicode (here I was wrong as I said string is empty)
hex2a("647E")
works and delivers "d~" as there are characters defined
and
hex2a("0a")
delivers the linefeed and Splitting works
var del = hex2a("0a");
Stack = s2Stack.split (del);
but this is equal to
Thanks Markus,
The hex business 'was necessary' because initially I did not split with "\n", but with "\\n" - which obviously is wrong... Analysing what is really in the string lead me to this erraneous deviation.
The ZTrace function now is this:
function ZTrace () { //==== Indicate calling sequence =============================================
// Returns  -
// Called by if (settings.IsDebug) {ZTrace ();}
var indent, name, level, aStack = [], sStack,
    dots = ".......................................................................................";
  sStack = $.stack.toString();
  aStack = sStack.split ("\n");
  level = aStack.length - 3;
  if (level > 0) {name = aStack[level]};
  indent = dots.substring(0, level*2);
//Console (indent + name);
  $.writeln (indent + name);
} // --- end ZTrace
Engaged ,
Hi Klaus,
glad you got this job done.
Here is a list of relevant escape sequences:
CodeOutputsHex Code
\'single quote0x27
\"double Quote0x22
\\backslash0x5C
\rCarriage Return0x0d
\nLine feed0x0a
\tHorizontal Tabulator0x09
For more Information visit: https://www.w3schools.com/js/js_strings.asp
double backslash means a realworld backslash, so you split statement searched for the real world string "\n" and not for the character "Linfeed (0x0a)".
Hope this helps anybody
Markus
