Use script and Grep to creat unique hyperlinks
Feb 13, 2017 Feb 13, 2017
I'm new to scripting and was wondering if it would be possible to creat unique hyperlinks based on a grep?
I have an indesign file with lots of six digit item numbers. Can I grep for \d{6} and create a hyperlink like google.com/123456 with that number as the anchor text? The digits are unique but the base URL is the same throughout (In this example google.com/).
I was trying with AppleScript but if the number repeated then the script failed.
Any help is is much appreciated.
Thank you
Scripting
861
New Here , Feb 14, 2017 Feb 14, 2017
I think I solved it with this:
var myDoc = app.activeDocument;
app.findGrepPreferences = app.changeGrepPreferences = null;
app.findGrepPreferences.findWhat = "\\d{6}-.{2}";
var myFound1 = myDoc.findGrep();
count = 0
for(k=0; k<myFound1.length; k++)
try{
var myFind = myFound1;
var myFound = (myFound1.contents);
var classNo = myFound.split("-");
var myHyperlinkSource = app.activeDocument.hyperlinkTextSources.add(myFound1)
var myHyperlinkURLDestination = app.activeDocument.hyperlinkURLDestinations
Enthusiast ,
Bonjour roba,
Regarde -> Create hyperlinks with script, without big increases to size and processing reqs of resulting PDFs?
voici :
#target "indesign-12.064"  // CC2017
var doc = app.activeDocument;
app.findGrepPreferences.findWhat = '\\d{6}';
var objs = doc.findGrep();
for (var i = 0; i < objs.length; i++) {
    var currTarget  = objs;
    var lnkDest = doc.hyperlinkURLDestinations.add("http://www.indesignjs.de/extendscriptAPI/indesign-latest/#Application.html");
    var lnkSrc = doc.hyperlinkTextSources.add(currTarget);
    var lnk = doc.hyperlinks.add(lnkSrc, lnkDest);
alert('Processed '+objs.length+' hyperlinks');
cet exemple est tiré du lien cité plus au il fonction.
count = 0
try{
var myHyperlinkURLDestination = app.activeDocument.hyperlinkURLDestinations.add("https://www.apexprd.org/scripts/webtrac.wsc/Wbsearch.html?xxmod=AR&xxactivitynumber="+classNo[0])
var myHyperlink = app.activeDocument.hyperlinks.add(myHyperlinkSource, myHyperlinkURLDestination, {name: myFound1.contents+count++})
count++
}catch(e){}
alert(count/2 + " occurencces is changed")
