Put focus on insertion point..
Enthusiast ,
Feb 13, 2017 Feb 13, 2017
I'm trying to put the focus on the insertion point after inserting text from a palette without mouseclick.
I just want to continue writing at that point.
Things I've already tested:
- scrollToText
- oDoc.IsInFront = 1
- oDoc.TextSelection = tRange
Has anybody solved this problem?
var w = new Window ("palette","INSERT");
    w.Button = w.add("button",undefined,"Go")
    w.Button.onClick = Insert;
    w.show()
function Insert()
var oDoc = app.ActiveDoc
var textLoc = oDoc.TextSelection.beg;
oDoc.AddText (textLoc, "Test");
Scripting
6.0K
Explorer , Jul 13, 2023 Jul 13, 2023
You may have already solved it, but using Fcodes() will do the trick.
#target framemaker
    w.show()
function Insert() {
    var oDoc = app.ActiveDoc;
    //A graphic toolbar appears and App focus returns to document.
    Fcodes([FCodes.KBD_TOOLWIN]);
Klaus,
I have a function DisplayMarker which might give a hint:
function DisplayMarker (oDoc, oCurrentMarker) {
//          Select marker to visualize the location of the current marker
//          (Text Symbols must be on to see it)
var myTextRange, oTextLoc1, oTextLoc2;
  if (oCurrentMarker.ObjectValid()) {
    oTextLoc1 = oCurrentMarker.TextLoc;
    oTextLoc2 = oCurrentMarker.TextLoc;
  } else {
    alert ("DisplayMarker:\nPgm error: oCurrentMarker not defined.", DisplayMarker.name, true);
    return false;
  oTextLoc2.offset = oTextLoc2.offset+1;                  // offset2 = offset1 is given by oTextLoc
  myTextRange  = new TextRange(oTextLoc1,oTextLoc2);      // define a TextRange
  oDoc.TextSelection = myTextRange;              // if you want to select the marker
  oDoc.ScrollToText(myTextRange);                // requires a TextRange. NOT a location
} //--- end DisplayMarker
It works fine.
Enthusiast ,
Hi Klaus,
thanks a lot for your suggestions.
The problem is, to put the focus on the document, when working with a palette-window.
In my little script above, when you click "Go", the text is inserted at the insertion point.
What I want to do then is, just to write in the document, without clicking with the mouse to the insertion point.
- scrollToText
I've also tested Shift - F7: no success.
Now I understand: I also had no success in doing this.
I needed to resort to "documentation change"...
function SetFocusToDoc (oDoc) { //=== Set focus back to document after invoking panel =============
// Comment  Since the panels are per definition 'in front' they can not be influenced to give
//          focus back to the document. The user must click into the document to get it in focus
//          to be able to enter another shortcut. Of course the focus of the panel is left also
//          when reaching for the menu.
//          HENCE THIS FUNCTION IS NOT USED …
// Reference Klaus Göbel at https://forums.adobe.com/thread/2240541
var oTextRange, fcode = [];
  oTextRange = oDoc.TextSelection;
  oDoc.ScrollToText (oTextRange);
  oDoc.IsInFront = 0;                            // method Klaus Göbel -> no effect
  oDoc.IsInFront = 1;
  fcode[0] = FCodes.FOCUS_INPUT_DOC;  // <Definition \x620> new idea - no effect
    Fcodes(fcode);
} //--- end SetFocusToDoc
This seems to be a panel quirk
Enthusiast ,
Hi Klaus,
thanks a lot, pointing to that solution. I'll try to work it out and give you a feedback.
  1. oDoc.IsInFront = 0;
  2. oDoc.IsInFront = 1;
Doing that workes only if at least 2 dokuments are open.
Ergo: It doesn't work.
Engaged ,
Klaus,
I think there are two changes to get this done as ES has no window handling mechanism.
1. implement an FDK Client, which gives you access to the windows, then you'll be able to active the active document window
2. find a workaround with any function that could activate current active doc window.
Point 1, I think it's too much overhead for this. As "IsInFront" works when two documents are open but not if only one is opened, following thoughts
1. try
Assign an invalid doc to app.ActiveDoc
var doc = app.ActiveDoc
app.ActiveDoc = app.ActiveDoc.NextDocumentInSession
app.ActiveDoc = doc;
2. try
Minimize active doc and maximize it again
app.ActiveDoc.IsIconified = true;
app.ActiveDoc.IsIconified = false ;
or perhaps
app.ActiveDoc.IsOnScreen = false;
app.ActiveDoc.IsOnScreen = true;
or a combination of IsOnScreen and IsInFront
3. try
Call something like Redisplay/Reformatting
4. try
keep an hidden (empty) document. Make it visible, make it the activeDoc and than switch back to your document and hide your dummy again.
Sorry, not nice but perhaps could help
Markus
Enthusiast ,
Feb 14, 2017 Feb 14, 2017
Hi Markus,
None of them works. The only way seems to be fcode[0] = FCodes.FOCUS_INPUT_DOC;
But there is absolutely no effect. So maybe it's a bug.
All other things only cause flickering.
Engaged ,
Hi Klaus,
I woudn't call it a bug. Bug is such a hard word 🙂
I think, this all is due to a missing window messaging queue support within ExtendScript. Perhaps @AdobeTCS could bring some C-features like "BringWindowToFront" up to ExtendScript.
Window focus is on your ES Dialog, and you can't change this Focus without messaging queue support.
So I think the only way to make this work in a stable way is an FDK Client which implements a callback to FA_NoteCallClient and implements this window handling.
Sorry
Markus
Mentor ,
Feb 15, 2017 Feb 15, 2017
Hi Klaus G.,
Any time I need to force a document to the front (that is, "brute force"), I call Open() on it again. Did you try that? Maybe something like:
SimpleOpen(oDoc.Name, false);
Russ
Enthusiast ,
Hi Russ,
thanks for your advice.
In my case, the document already is open and on top of all other documents or it is the only open document.
But the palette-dialog overlaps it.
I have a (palette-)script, that inserts words by pressing a button. I want that the user can continue writing without having to "aim"  with the mouse without closing the dialog.
Mentor ,
Hi Klaus,
I understand that. I have found that an "open" command on an open document tends to force it to the front, when other options fail. Did you try it?
Russ
Enthusiast ,
Hi Russ,
I've just tried. It only flickers.
Klaus
Mentor ,
Confound it! I thought I had the answer. Thanks for trying.
Engaged ,
Feb 16, 2017 Feb 16, 2017
just another idea:
try to set active property of your palette to false and after that try one of suggestions above.
Would start with SimpleOpen, as Russ suggested.
Markus
Mar 01, 2017 Mar 01, 2017
Following Markus' last advice I can place the text:
#target framemaker
        w.show()
function Insert()  {
    w.active = false;   // Markus' suggestion
So, does this work in a real-world script also?
#target framemaker
    w.show()
function Insert() {
Enthusiast ,
Jul 14, 2023 Jul 14, 2023
Thanks a lot.
That did the trick !
