Hi All
I followed this thread:
Coldfusion 10 Case Sensitive URLs?!?
By editing the context.xml file as suggested. This resulted in the following error:
type Exception report
message java.lang.NullPointerException
description The server encountered an internal error that prevented
it from fulfilling this request.
exception
javax.servlet.ServletException: java.lang.NullPointerException coldfusion.bootstrap.ClassloaderHelper.initServletClass(ClassloaderHelper.java:129) coldfusion.bootstrap.BootstrapServlet.init(BootstrapServlet.java:59) org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505) org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103) org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:956) org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:450) org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:197) org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:625) org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:316) java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) java.lang.Thread.run(Unknown Source)
root cause
java.lang.NullPointerException coldfusion.CfmServlet.init(CfmServlet.java:97) coldfusion.bootstrap.ClassloaderHelper.initServletClass(ClassloaderHelper.java:121) coldfusion.bootstrap.BootstrapServlet.init(BootstrapServlet.java:59) org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505) org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103) org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:956) org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:450) org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:197) org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:625) org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:316) java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) java.lang.Thread.run(Unknown Source)
note The full stack trace of the root cause is available in the
Apache Tomcat/7.0.68 logs.
Unfortunately, reverting the context.xml file to it's original state does not fix this error! I have ready that a complete reinstall may be required, but I cant think this would be the solution as ive only edited a single file rather than installing an update etc!
Any suggestions?
cheers
Have something to add?
