Anybody encountered this problem when you set the resolution to Full? It comes out normally when I render out, just displays like this. All other resolutions work perfectly.
I have seen similar problems that were related to the GPU driver. Try updating it through the manufacturer website or rolling back versions and see if this is resolved
I have AMD Radeon R9 200 Series with the latest drivers. Any known issues?
What happens if you zoom your comp to 100% instead of 25%?
Zooming does fix it, 50% and higher is perfect. Any way to fix anything lower? I'd quite like to see the entire comp at once
If you are viewing your comp at 25% zoom level, you might as well also view it at quarter resolution too because there will be little to no difference. Well, except that it will render your previews much more quickly! I set my resolution to automatically follow the zoom level. That way, I'm not wasting time for it to render something at full res when I'm only looking at it at half-size (or whatever).
I'm not saying this isn't a bug (and I am saying you should file a bug report), but you're trying to do something unnecessary. Just set your comp resolution to auto and be worry-free!
