I've build a client site using the full width screen display. When I resize the browser window everything fills in nicely. But when use I use my mouse and slide screen to the left a white space appears to the right. Could anybody help me figure out why this is happening?
mkfcommunications.com
Did you make sure, that no element of your layout- or master page overlaps/is placed outside the defined breakpoint and/or page width?
You may check this by zooming out to see the complete page and perform a "Select All".
Thank you so much for your quick response, Günter. That's exactly what I did to solve a sizing problem I was having with one of the background images. I will work on a different solution so I can make everything fit correctly. Thanks again!
