Hello,
I try this simple script.
Extendscript returns error "cannot handle the request because a modal dialog or alert is active".
"w.close()" seems not working.
Don't understand why, can somebody explain me please?
#target "InDesign"
#targetengine "main"
win();
function win() {
var w = new Window ("palette", "UI");
var myBtn = w.add ("button", undefined, "nouveau document");
myBtn.onClick = function() {
w.close();
newDoc();
w.show ();
function newDoc (){
var doc = app.documents.add(true);
with(doc.documentPreferences){
pageHeight = "2000mm";
pageWidth = "2000mm";
pageOrientation = PageOrientation.landscape;
pagesPerDocument = 1;
Because the dialog isn't really close yet.
You have to execute your routine this way:
...win();
function win() {
var w = new Window ("dialog", "UI");
w.close(1);
var myBtn = w.add ("button", undefined, "Annuler");
w.close(0);
if ( w.show ()==1 ) newDoc();
function newDoc (){
var doc = app.d
It works, when using #targetengine "session" and creating 'palette' instead of 'dialog'.
I don't really understand why it didn't work before.
If somebody can explain me…
Thanks.
Hi jjrger,
The reason your original script didn't work is exactly what ExtendScript told you: "cannot handle the request because a modal dialog or alert is active". In other words, DOM commands—such as app.documents.add(true)—are unavailable from a modal dialog. You need to either close the dialog before sending the command, or to base your code on a non-modal window ('palette' or 'window' type.)
Marc
Thank you Marc,
But the script ask w.close() before sending the command. That why I don't understand. Is there a timing explanation??
Jimmy
win();
function win() {
w.close(1);
w.close(0);
function newDoc (){
Have a look at ScriptUI for Dummies from Peter Karhel:
To complement Loïc's answer, I think important to mention that myWindow.close() is something of a ScriptUI command which notifies an event through the Window component. At this point, other events may still need to be handled (e.g. onClose, onDeactivate…).
So myWindow.close() does not result in myWindow.active==false. In fact the window remains active as long as its inner event loop is running. The rule is, you can't have your modal window in a non-active state from within any event handler. You need to exit the ScriptUI layer, which is guaranteed once w.show() has returned.
Marc
Thanks to you both for these precisions.
The uses of palette, dialog, and the event timing of window close are more clear for me.
Merci beaucoup!
Jim
