Is it possible two set up a text frame with a single column header and a double column body? I am making a menu and that would be my ideal setup. I am using Indesign CC 2017 on a MAC
Check out the split/span columns feature.
The Span and Split Columns feature has been available since InDesign CS5:
http://indesignsecrets.com/timesaver-span-and-split-columns-in-cs5.php
Here's a video that explains the Span Columns feature Bob and Steve are referring to: http://www.jeffwitchel.net/2011/11/indesign-make-your-headline-span-columns/
I am working on my first ever catalog design trying to clean up things from the previous designers catalog, Your video saved me so much time and hassel, as well as helping me keep the layout extra clean. Thank you.
Thanks every one for the good information.
If your question has been answered, please mark the correct answer. Any of the above looks correct to me.
Sorry about that. I didn't see the correct answer option at first.
