I've read this thread on checking for layer effects using ActionManager code: How to get the style of a layer using photoshop scripting ??
And I'm using the below code to try and check for the bevel and emboss effect:
// Checks for bevel and emboss effect
function sTID(s){ return app.stringIDToTypeID(s); };
var ref = new ActionReference();
ref.putEnumerated(sTID("layer"), sTID("ordinal"), sTID("targetEnum") );
res = executeActionGet(ref).getObjectValue(sTID("layerEffects")).hasKey(sTID("bevelEmboss"));
alert(res);
But the problem here is that it returns true for ALL layer effects. Why?
I'm using the below code to check for the stroke FX and it works as expected - but as you can see, changing the TypeID in the hasKey() -function doesn't seem to be working.
// Checks for stroke effect
res = executeActionGet(ref).getObjectValue(sTID("layerEffects")).hasKey(sTID("frameFX"));
alert(res);
Another inconsistency is that if you have multiple effects, the layer effect is sometimes not found at all - unless you manually go into the effects options and chose "delete hidden effects". You can try this with the following code for instance:
// Checks for the drop shadow effect
res = executeActionGet(ref).getObjectValue(sTID("layerEffects")).hasKey(sTID("dropShadow"));
alert(res);
// Checks for bevel and emboss effect function
var desc = executeActionGet(ref).getObjectValue(sTID("layerEffects"));
if(desc.hasKey(sTID("bevelEmboss"))){
alert("Has bevelEmboss");
}else{
alert("does not have bevelEmboss");
That is the same code that I use and I get false-positives with it
Update to original post:
Checking for layer effects breaks when there are two of the same layer effects active. Most likely a key error.
Bevel and Emboss is broken - It gives false positives all the time.
Satin is also broken - Like Bevel and Emboss it also gives false positives all the time.
Might be down to the Photoshop version? CS6 is ok.
Possibly. I'm on CC 2017 right now.
Another update:
The keys for each layer effect change when there are multiple effects of the same kind. Example:
Say that you have one inner shadow effect. Then the key is "innerShadow". But if you have 0 or 2+ innerShadow effects then the key is "innerShadowMulti". This can be confirmed with this code:
result = executeActionGet(ref).getObjectValue(sTID("layerEffects")).getKey(2);
result = typeIDToStringID(result);
alert(result);
Now run that code in jsh on a layer with 0, 1 and 2 Inner Shadow -effects. You will get "innerShadow" when there is only 1 effect of this kind, but "innerShadowMulti" when there is 0 or 2+ effects. I've found that the reason for this behavior is different from the Satin and Bevel&Emboss -FX is that in the case of the latter two, there can only be one of a kind on a layer. In other words: a layer can have multiple drop shadow FX, but only one Bevel&Emboss. My conclusion is that in order to determine the status of all layer effects, we have to go deeper into the object.
I have also discovered that once you apply a layer effect to a layer, the following keys are added to the layer effects -descriptor:
bevelEmboss
chromeFX
...and this happens even if you DON'T add these effects to the layer and even if you DO "delete hidden effects".
In other words: you have to go deeper into the object and actually have a look at the attributes -_- Why Adobe, WHY?
