Good evening guys
I have the following problem.
I made a chart which according to the percentage, changes the BAR width. I have made and a cycle which follows the bar, but when I PARENT with the BAR to following, changed and in the cycle the width relative to the bar. How to become the "lock" the width and the Cycle only follow the bar;
I have tried to lock it putting on scale the expression [100, 100] but it does not work...again changes the width according the Bar
Sorry for my English
Thank you very much
John K.
It works as it is supposed to. You will have to use expressions and not parenting.
Mylenium
I fix it with the linear expression!
Thanks my friend
John K.
You can help me Mylenium with the expression which ι should be put on Ball Shape to follow the width percent on Bar shape?
I Put on Ball Shape at X Position this expression: thisComp.layer("Ball Prossesion - Static Bar 1").transform.scale[0]
The Ball Shape take the value from Ball Prossesion - Static Bar, but the Scale is in Percent and the X Position is in pixels.
When i change the Percent, the Ball change litle pixles only...
Thanks again!
John K.
