Every object i place there seems to be some kind of dotted border around them and it is making working very tedious.
They don't print, do they?
Those dotted borders normally indicate that those objects are on the master page, and you are seeing them on a body page.
Try View > Extras > Hide Frame Edges.
Thank you very much!!
You are very welcome!
And the pink background you see behind the text in your screen shot indicates missing fonts, as per Vinny's note, above. You can:
By the way... check out missing fonts
Glad you found the correct answer!
However, just to further Barb's point if you ever have any doubt you can (aside from printing) also switch to preview mode to check the box's you are seeing are just visual guides rather than actually there.
Best,
EW
If it is every object, make sure you are not actually working on a Master page.
It could also be Extras > Hide Hyperlinks
cheers
-David
This was my problem, thanks!
